papaG4
#1 Posted : Thursday, June 25, 2026 4:54:22 AM(UTC)
papaG4
France, Metropolitan
Bonjour,
I have audio clicks and cuts when I read video files.
I use VMIX to project video files in our auditorium: I send output to FullScreen ( to the Epson videoprojector ) and have a MOTU audio interface for the sound system.
Sound cut and clic as there are no problem reading the file un VLC ?
I use VMIX 29.0.0.48 and Windows 11 updated...
I use the MOTU audio wave 64bit and I try with the MOTU ASIO... but problem is the same.
It's very annoying for the audience!
any idea ?
Ronan
from Paris France !
#2 Posted : Thursday, June 25, 2026 7:00:38 AM(UTC)
Originally Posted by: papaG4 Go to Quoted Post
Bonjour,
any idea ?
Ronan
from Paris France !
check if the audio of the files or the playback have a DC offset (this was the case with some of my recordings from a particular camera)
if that is the case you can use a VST plugin to rectify that
papaG4
#3 Posted : Thursday, June 25, 2026 7:47:06 PM(UTC)
papaG4
Bon, I use this PC with Protools too and I change the "samples per buffer" ! (512 to 128) for audio recording.
I set back the "Samples per Buffer" to 512 and it's OK .
For audio 128 samples at 48k is 3ms : good for audio recording
512 samples at 48k is 11ms : good for VMIX as render time in my case is 5ms to 12ms...
Ronan
PS: these are movies so I didn't check offset DC.
I just ajust FPS from 24 to 25 (using Shutter Encoder) and it reduce the amount of GPU Mem from 59% to 44%. I have a RTX 2060.
thanks 1 user thanked papaG4 for this useful post.
jet on 6/25/2026(UTC)
jet
#4 Posted : Thursday, June 25, 2026 10:09:57 PM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Newer heard of this software before. Thanks for sharing.
