#1 Posted : Wednesday, November 4, 2026 4:08:39 PM(UTC)
Was thanked: 4747 time(s) in 1632 post(s)
vMix 30 Preview (30.0.0.22 Beta) is here!
Disclaimer: This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Your feedback is greatly appreciated, please report any bugs or issues in the Beta Discussion forum.
Updates: If you purchased vMix prior to 1 January 2023, an additional purchase is required to use this beta or a new Trial may be possible if you have only used the Trial once in the past. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates.
https://account.vmix.com/order/?Upgrade=1
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
https://cdn.vmix.com/download/vmix30preview.exe
New Features and Changes
Audio
* New Noise Suppression effect on Inputs and Audio Buses
Includes support for NVIDIA Audio Effects Denoiser and Dereverb on RTX series graphics cards
* New Headphones Post Master Fader option on the Master audio settings
* Audio meters now include dynamic peak indicators
GT
* Text Letter Spacing support
* High quality masking support including inverted masks
* Copy Properties menu allows copying object settings once and pasting on multiple destination objects
* Eye dropper tool added to color selection window allows selecting a color anywhere on screen
* Added ability to change the properties of multiple objects at a time
* Data tab has new Show Text Color checkbox, this enables the Text.Fill.Color data source field
Replay
* Increased number of cameras supported from 8 to 16
* Allow importing clips in a variety of formats into a spare camera channel assigned to Clips
* Added new ReplayAPI and ReplayEventsAPI to show events and timing information
* New ReplayJumpFramesAcceleratedFast, ReplayJumpFramesAcceleratedMedium, ReplayJumpFramesAcceleratedSlow shortcuts
that will jump frames at an accelerated rate when moving the jog wheel faster.
* Added ReplayExportAllEvents, ReplayExportSelectedEvents, ReplaySelectEventsByID, ReplaySetEventCamerasByID, ReplaySetEventTextCameraByID shortcuts
* New option in settings to automatically play when speed goes above 0%
Browser
* Built in browser updated to Chromium V152
Outputs
* Increased outputs from 4 to 8 in 4K, Pro and Max editions
This requires recent generation high end GPUs, Intel Core Ultra CPUs, DDR5-6000 memory and Resizable Bar enabled for good results
* Added 8-bit to 10-bit conversion option for DeckLink IP cards when used with External Output
Capture
* Added support for latest AJA capture devices including IP25, Kona X and Corvid 88 Gen 3
* Added support for 16CH audio with DeckLink cards for both input and output where supported by the card
NDI
* NDI version updated to 6.3.2
* Upcoming NDI 6.4 with support for recording NDI directly to MKV in MultiCorder preserving original video, audio and metadata
(NDI 6.4 will be included as soon as officially released by NDI)
Video
* Built-in FFMPEG decoders updated to 8.1.1 to support playback of newer formats including AV1 videos
PowerPoint/Photos
* Added built in support for importing PowerPoint slideshows without requiring Microsoft PowerPoint to be installed
* Added a new Presenter Mode that allows previewing slides prior to displaying them live
List
* Added Mouse Wheel support for scrolling through List
* Added progress indicator display showing Total Position (POS), Total Remaining (REM), Total Duration (DUR)
These indicators count all enabled items in the list where Auto Next is enabled, otherwise only count the currently playing item
* Added shortcuts to disable/enable and toggle items in the List
Data Sources
* Added additional Text, Number, Milliseconds and DateTime formatting options when assigning a data source to a text field.
Mix Inputs
* Added Tally Passthrough option for Mix Inputs. When enabled any inputs used in the Mix Input and any layers will trigger on the tally indicators
for that input.
Production Clocks
* Added Message option to display short messages on the production clock.
* Added right click menu to open Production Clock settings from the input in addition to the main interface
* Added new shortcuts for setting Production Clock Message and Type
MultiView Output
* Added three new layouts for 10, 12 and 24 inputs displayed at a time.
Overlays
* New designer added to Overlay Settings for adjusting position of Picture In Picture
* New Effects tab added to Overlay Settings allows adding effects such as shapes and alpha masks to the overlay
Effects
* Alpha Mask effect now supports shapes and basic borders
SRT
* Updated version to 1.5.7
* Added support for custom aspect ratios on Input
* Added support for streaming to SRT from the Streaming window instead of Outputs using an srt:// URL
This is designed for streaming providers that accept SRT instead of RTMP. The Outputs method should still be used for point to point
feeds.
Misc
* Title Text Editor: Added support for changing Title Preset order and also deleting multiple presets at a time
* Added support for 119.88 frame rate
* Added SetLayerDynamic shortcut to change input layer number based on DynamicValue1 value
* Added scroll bars to Zoom mode on Input Settings preview
* Higher quality deinterlacing enabled by default for 1080i, 576i and 480i, can be disabled in Settings - Decoders
Documentation
https://help.vmix.com/30/
No LLMs were used in the coding of this release. For more information see https://www.noclankersalliance.com/
doggy on 11/4/2026(UTC)
chezter, Guest (10)
