#1 Posted : Wednesday, November 4, 2026 4:08:39 PM(UTC)
Was thanked: 4764 time(s) in 1636 post(s)
vMix 30 Preview (30.0.0.22 Beta) is here!
Disclaimer: This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Your feedback is greatly appreciated, please report any bugs or issues in the Beta Discussion forum.
Updates: If you purchased vMix prior to 1 January 2023, an additional purchase is required to use this beta or a new Trial may be possible if you have only used the Trial once in the past. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates.
https://account.vmix.com/order/?Upgrade=1
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
https://cdn.vmix.com/download/vmix30preview.exe
New Features and Changes
Audio
* New Noise Suppression effect on Inputs and Audio Buses
Includes support for NVIDIA Audio Effects Denoiser and Dereverb on RTX series graphics cards
* New Headphones Post Master Fader option on the Master audio settings
* Audio meters now include dynamic peak indicators
GT
* Text Letter Spacing support
* High quality masking support including inverted masks
* Copy Properties menu allows copying object settings once and pasting on multiple destination objects
* Eye dropper tool added to color selection window allows selecting a color anywhere on screen
* Added ability to change the properties of multiple objects at a time
* Data tab has new Show Text Color checkbox, this enables the Text.Fill.Color data source field
Replay
* Increased number of cameras supported from 8 to 16
* Allow importing clips in a variety of formats into a spare camera channel assigned to Clips
* Added new ReplayAPI and ReplayEventsAPI to show events and timing information
* New ReplayJumpFramesAcceleratedFast, ReplayJumpFramesAcceleratedMedium, ReplayJumpFramesAcceleratedSlow shortcuts
that will jump frames at an accelerated rate when moving the jog wheel faster.
* Added ReplayExportAllEvents, ReplayExportSelectedEvents, ReplaySelectEventsByID, ReplaySetEventCamerasByID, ReplaySetEventTextCameraByID shortcuts
* New option in settings to automatically play when speed goes above 0%
Browser
* Built in browser updated to Chromium V152
Outputs
* Increased outputs from 4 to 8 in 4K, Pro and Max editions
This requires recent generation high end GPUs, Intel Core Ultra CPUs, DDR5-6000 memory and Resizable Bar enabled for good results
* Added 8-bit to 10-bit conversion option for DeckLink IP cards when used with External Output
Capture
* Added support for latest AJA capture devices including IP25, Kona X and Corvid 88 Gen 3
* Added support for 16CH audio with DeckLink cards for both input and output where supported by the card
NDI
* NDI version updated to 6.3.2
* Upcoming NDI 6.4 with support for recording NDI directly to MKV in MultiCorder preserving original video, audio and metadata
(NDI 6.4 will be included as soon as officially released by NDI)
Video
* Built-in FFMPEG decoders updated to 8.1.1 to support playback of newer formats including AV1 videos
PowerPoint/Photos
* Added built in support for importing PowerPoint slideshows without requiring Microsoft PowerPoint to be installed
* Added a new Presenter Mode that allows previewing slides prior to displaying them live
List
* Added Mouse Wheel support for scrolling through List
* Added progress indicator display showing Total Position (POS), Total Remaining (REM), Total Duration (DUR)
These indicators count all enabled items in the list where Auto Next is enabled, otherwise only count the currently playing item
* Added shortcuts to disable/enable and toggle items in the List
Data Sources
* Added additional Text, Number, Milliseconds and DateTime formatting options when assigning a data source to a text field.
Mix Inputs
* Added Tally Passthrough option for Mix Inputs. When enabled any inputs used in the Mix Input and any layers will trigger on the tally indicators
for that input.
Production Clocks
* Added Message option to display short messages on the production clock.
* Added right click menu to open Production Clock settings from the input in addition to the main interface
* Added new shortcuts for setting Production Clock Message and Type
MultiView Output
* Added three new layouts for 10, 12 and 24 inputs displayed at a time.
Overlays
* New designer added to Overlay Settings for adjusting position of Picture In Picture
* New Effects tab added to Overlay Settings allows adding effects such as shapes and alpha masks to the overlay
Effects
* Alpha Mask effect now supports shapes and basic borders
SRT
* Updated version to 1.5.7
* Added support for custom aspect ratios on Input
* Added support for streaming to SRT from the Streaming window instead of Outputs using an srt:// URL
This is designed for streaming providers that accept SRT instead of RTMP. The Outputs method should still be used for point to point
feeds.
Misc
* Title Text Editor: Added support for changing Title Preset order and also deleting multiple presets at a time
* Added support for 119.88 frame rate
* Added SetLayerDynamic shortcut to change input layer number based on DynamicValue1 value
* Added scroll bars to Zoom mode on Input Settings preview
* Higher quality deinterlacing enabled by default for 1080i, 576i and 480i, can be disabled in Settings - Decoders
Documentation
https://help.vmix.com/30/
No LLMs were used in the coding of this release. For more information see https://www.noclankersalliance.com/
thanks 12 users thanked admin for this useful post.
doggy on 11/4/2026(UTC), jet on 11/4/2026(UTC), chezter on 11/4/2026(UTC), Chircanu on 11/4/2026(UTC), Edy Santos on 11/4/2026(UTC), Follo on 11/4/2026(UTC), Ario on 11/4/2026(UTC), ryxyz on 11/5/2026(UTC), eduardocfs on 11/5/2026(UTC), sinc747 on 11/5/2026(UTC), machadofernandoeng on 11/5/2026(UTC), monamiga on 11/5/2026(UTC)
mnmilos
#2 Posted : Wednesday, November 4, 2026 8:57:47 PM(UTC)
mnmilos
Serbia
DISCARD deinterlacing method looks like 25fps instead of 50fps (when source is 1080i50) when High Quality Deinterlacing is enabled.
If you disable High Quality Deinterlacing then there is 50fps like it was before but with flicker (like it was before with 29 vMix version).
What actually High Quality Deinterlacing do and when is active? Which deinterlacing method uses?
Can you add for testing purpose yadifx2 and bwdif?
There are also version for NVIDIA cards doing that job yadif_cuda and bwdif_cuda.
Thanks.
avsoundguy
#3 Posted: : Wednesday, November 4, 2026 10:20:20 PM(UTC)
avsoundguy
#4 Posted : Wednesday, November 4, 2026 11:06:35 PM(UTC)
vMix 30.0.0.23 Beta
* Fix for incomplete image when using 8 to 10bit conversion on DeckLink External Output
* Fix for deinterlacing reverting to Discard when it should be using Bob method
jet on 11/5/2026(UTC)
#5 Posted : Wednesday, November 4, 2026 11:08:10 PM(UTC)
Thanks.
This should now be fixed in 30.0.0.23
As for the method used, this is intentionally not documented so we can use better methods in the future if they meet a certain low latency performance threshold.
(Where we find CPU impact is not significant on modern PCs)
Unfortunately the methods you note are either too CPU consuming, require future frames to work (latency) or not compatible with the formats and methods vMix uses internally, so they cannot be considered at this time.
sinc747
#6 Posted : Thursday, November 5, 2026 3:24:30 AM(UTC)
sinc747
Was thanked: 205 time(s) in 171 post(s)
Bravo!
- Tom
aircooled76@gmail.com
#7 Posted : Thursday, November 5, 2026 11:55:07 AM(UTC)
Thanks for the upgraded Replay API!!!!!
Thank you thank you thank you! (although I just completed a work around program to get around it, but Ill take it!)
#8 Posted : Thursday, November 5, 2026 5:17:22 PM(UTC)
vMix 30.0.0.25 Beta
* Fix Replay Controller columns not working correctly when using full 16 cameras
* Allow routing HDMI output through channel 2 on AJA devices
* Update List display times to show three digit clocks to match Preview/Output display
* Update List to factor in a disabled but still playing video in duration times
* Fix SetProductionClockXMessage not allowing empty text
thanks 3 users thanked admin for this useful post.
jet on 11/5/2026(UTC), monamiga on 11/5/2026(UTC), ryxyz on 11/6/2026(UTC)
mnmilos
#9 Posted : Thursday, November 5, 2026 6:13:32 PM(UTC)
mnmilos
Serbia
Still doesn't get what Use high quality deinterlacing where available actually do?
#10 Posted : Thursday, November 5, 2026 10:12:33 PM(UTC)
It will use a higher quality deinterlacing algorithm than previous versions of vMix.
The details of that algorithm are not documented as they are subject to change.
The only guarantee is it will always be the highest possible quality vMix supports when checked.
mnmilos
#11 Posted : Thursday, November 5, 2026 10:51:24 PM(UTC)
mnmilos
Serbia
But I tested this and didn't see any improvement.
Capture card I use is Decklink SDI Micro and input is 1080i50 - flicker can be seen on vector graphic elements (titles and ticker) like I mention before.
I have tested with enabled and disabled higher quality deinterlacing but I don't see any diference.
#12 Posted : Thursday, November 5, 2026 11:10:26 PM(UTC)
The difference is subtle when viewing directly within the vMix previews/fullscreen.
The most noticeable quality improvement is when sending it back out as interlaced via External Output or an interlaced Recording format.
In that case the field lines are directly preserved from input to output with HQ enabled.
mnmilos
#13 Posted : Thursday, November 5, 2026 11:33:23 PM(UTC)
mnmilos
Serbia
Thanks for detail. This is very good what you did.
My scenario is a little different:
- Interlaced cameras i50
- Preset is in progressive p50
- Stream and External is 50p
That's why I need good deinterlace, because the end is LED or STREAMING platform in high motion (like sports in 50fps).
For this scenario I use Discard and when I don't need high motion (25fps) then I use Blend deinterlace method.
Yadiffx2 worked the best for me by far. But that option is available in OBS and MagicSoft Gateway.
Thanks for all once again.
Edy Santos, Guest (6)
