Kibim
#1 Posted : Friday, March 29, 2019 8:11:25 PM(UTC)
Kibim
Hi All,
I've been struggling with this. I need to create a ticker from VMix Social.
If i create just a single ticker, i can only put a single field into the ticker.
With a social ticker, we obviously need to see "fromName" as well as "message". Is there a way of including BOTH fields into a ticker?
If i modify the existing vmix-social-ticker-GT it has fixed width and heights within the text blocks, and this doesn't work for a 'crawl' type ticker, where i land up with lots of black space, or adpative size text which then gets too small to read.
I'm not well versed with XAML at all, but i assume it's possible to add 2 strings into a single field, but how one goes about creating those variable entries, i don't know.
Regards
#2 Posted : Friday, March 29, 2019 10:53:18 PM(UTC)
Kibim
#3 Posted : Saturday, March 30, 2019 1:53:50 AM(UTC)
Kibim
Originally Posted by: doggy Go to Quoted Post
Thanks for the link, but that's not the same problem i'm having.
With Vmix Social, it requires 2 text fields to push "name" and "message" to, via the Edit Mappings button in Social.
A ticker seems to only be able to accept 1 field. Ideally i'd need to create something along the following lines, but nothing i've tried has worked :
<textblock Name="TextBlock1" Text="Pushed from VmixSocial here" + Name="TextBlock2" Text="Pushed from VmixSocial here too" />
Grids don't seem to work in Vmix, at least they're size adaptable.
This is what i currently have working, a bit of a modification of the existing VmixGTSocialTicker file, but it's a fixed size box, and if the message is longer or shorter, i land up with a long gap between messages, or text too small to read...
Alternatively, being able to adapt the dimention size to the length of the text would also work.
<Ticker Name="T" Dimensions="1915,75,0" Location="0,925,0" FontFamily="Segoe UI" FontSize="26" FontWeight="Bold" VerticalAlign="Center" Speed="5" Type="Add">
<Ticker.Template>
<TextBlock Name="FromNameHolder" Text="FromName" FontFamily="Segoe UI" FontSize="32" FontWeight="Bold" VerticalAlign="Center" />
<Layer Name="ContentLayer" Dimensions="1680,75,0" Locked="False">
<Layer.Composition>
<Composition Width="1680" Height="75">
<TextBlock Name="FromName" Dimensions="312,75,0" Location="60,-10,0" Text="FromName" FontFamily="Segoe UI" FontSize="32" FontWeight="Bold" VerticalAlign="Center" AutoSize="Shrink">
</TextBlock>
<Image Name="FromPhoto" Dimensions="50,50,0" Location="5,6,0">
<Image.Bitmap>
<Bitmap Source="57cf4bb7-5362-47c9-a366-4c810df41d6a\source1.png" />
</Image.Bitmap>
</Image>
<TextBlock Name="Message" Location="380,-10,0" Text="Message" FontFamily="Segoe UI" FontSize="30" VerticalAlign="Center" > <!--Dimensions="1300,75,0" AutoSize="Shrink"-->
</TextBlock>
</Composition>
</Layer.Composition>
</Layer>
</Ticker.Template>
</Ticker>
Simsyuk
#4 Posted : Friday, September 13, 2019 1:06:04 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Did you solve this issue, I'm having the same problem. I would like to resize the ticker box but I can't seem to find where to edit this. How did you use your script?
Guest (4)
Similar Topics
Social Ticker 1 (GT)
by Simsyuk 6/15/2022 5:56:23 PM(UTC)
vMix Social & Social Ticker Post Spacing (Feature Requests)
by TBacker 3/10/2021 12:48:10 PM(UTC)
Social ticker problem? (General Discussion)
by Hall3008 12/22/2020 9:21:53 PM(UTC)
GT Social Ticker 1 - Blue (GT)
by Simsyuk 9/13/2019 12:41:54 AM(UTC)
