Joined: 7/31/2016(UTC) Posts: 69   Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
How do I make my social ticker be in one line or can I determine in how many lines the ticker should run. See in the example? If I try to do it in GT Designer I can't change that option? I would need more characters in one line. Like a classic ticker but let it be a social ticker. Is that possible?  ticker.jpg (44kb) downloaded 0 time(s).
The social ticker from vMix ? That one is vertical not ?
in any case you will need to know in advance how long such a line would have to be and will be stuck with that regardless of the actual size/length of the text. There is a reason vMix social has a text limit option. No you can not edit that directly with the designer. What is wrong with a classic ticker ?
I canot use classic ticker for social message. Social ticker is ok but if you need left or right option then you canot in one line
