Hall3008
#1 Posted : Tuesday, December 22, 2020 9:21:53 PM(UTC)
Hall3008
Croatia
How do I make my social ticker be in one line or can I determine in how many lines the ticker should run. See in the example? If I try to do it in GT Designer I can't change that option? I would need more characters in one line. Like a classic ticker but let it be a social ticker. Is that possible?
#2 Posted : Tuesday, December 22, 2020 9:53:10 PM(UTC)
The social ticker from vMix ? That one is vertical not ?
in any case you will need to know in advance how long such a line would have to be and will be stuck with that regardless of the actual size/length of the text. There is a reason vMix social has a text limit option. No you can not edit that directly with the designer. What is wrong with a classic ticker ?
Hall3008
#3 Posted : Tuesday, December 22, 2020 10:51:38 PM(UTC)
Hall3008
Croatia
I canot use classic ticker for social message. Social ticker is ok but if you need left or right option then you canot in one line
