3 Pages123>
#1 Posted : Thursday, August 22, 2013 7:39:07 AM(UTC)
Was thanked: 4691 time(s) in 1611 post(s)
vMix Title Designer is a new design tool that allows you to easily create title templates in vMix.
Overview
vMix Title Designer is a simple way of integrating existing graphics with text fields that can be edited live.
For example, first create the title or lower thirds graphics you would like to use in a graphics program such as Photoshop or Illustrator.
Then export it as a PNG with transparent background.
Though the drag and drop interface you can set a background image and add text and image objects.
Once the template is complete, simply save and open it in vMix using the "XAML" input option.
From there you can edit any text field directly within vMix.
Notes
* All images you use will be automatically saved in the same folder as the final title template, so it is recommended
you create separate folders for each title so everything is kept together.
* The background image will be automatically stretched to fill the entire template so it should be created in the same resolution as the title.
(By default this is Full HD 1920x1080)
Download
vMix Title Designer is included with all versions of vMix. To open the vMix Title Designer, search the Start Menu.
thanks 10 users thanked admin for this useful post.
Adriankey4 on 8/22/2013(UTC), Damn2Good4U on 8/22/2013(UTC), watchfulone on 8/23/2013(UTC), atpt on 8/24/2013(UTC), OpenROADer on 8/25/2013(UTC), Greg on 8/30/2013(UTC), peterphelan on 9/1/2013(UTC), sontoloyo on 9/5/2013(UTC), madness on 2/19/2014(UTC), ferdi82 on 10/19/2016(UTC)
Adriankey4
#2 Posted : Thursday, August 22, 2013 11:36:36 AM(UTC)
Adriankey4
Jamaica
Thanks Martin!!!
Could you also add a section where we can add video sources with alpha channel please?
By:
Adrian
Jamaica, W.I.
Damn2Good4U
#3 Posted : Thursday, August 22, 2013 11:57:22 AM(UTC)
Damn2Good4U
Well done Martin.
This is cool
LaserHarp
#4 Posted : Thursday, August 22, 2013 1:12:44 PM(UTC)
LaserHarp
Thanks a lot Martin. Very good tool.
Regards
watchfulone
#5 Posted : Friday, August 23, 2013 1:33:03 AM(UTC)
watchfulone
You have been a member since:: 11/15/2010(UTC)
Was thanked: 17 time(s) in 14 post(s)
admin wrote:
vMix Title Designer (1.0.0.0) Beta is a new design tool that allows you to easily create title templates in vMix.
Overview
Notes
* This is a Beta release, so please report any bugs in this thread.
Download
http://www.vmix.com.au/d...ad/vMixTitleDesigner.exe
Looking good Martin, testing now, i notice that when selecting font size there is no drop down arrow to select the size number of the text, I have to highlight the default number and type it manually on the keyboard. And oh yeah no animation.
But I must say this is wonderful, very wonderful
thanks 1 user thanked watchfulone for this useful post.
JodyK on 9/13/2013(UTC)
Marco R.
#6 Posted : Friday, August 23, 2013 8:50:41 AM(UTC)
Marco R.
Nice!
Would like in the Misc; DropShadowEffect BlurRadius ShadowDepth
Regards
amsudeen
#7 Posted : Friday, August 23, 2013 11:53:54 PM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
Nice!
stroke should be outoor ( now it is inner )
Would like in the Misc; DropShadowEffect BlurRadius ShadowDepth and animation.
thanku
thecloudmediagroup
#8 Posted : Tuesday, August 27, 2013 10:44:32 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
Wow! This is great!!! Thank you:)
Greg
#9 Posted : Friday, August 30, 2013 10:16:28 PM(UTC)
Greg
I was able to go into the xaml file and make changes to create my own titles but this makes it a lot easier.
Thanks Martin
Greg
dundurs
#10 Posted : Wednesday, September 4, 2013 10:43:32 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
One problem I cam across - whenever I update the xaml using Title Designer and reload vMix Preset to reload the updated title, I still get the old version. It looks like there is some caching going on.
If I add the xamle as a new input, the updated version appears.
watchfulone
#11 Posted : Wednesday, September 4, 2013 10:24:22 PM(UTC)
watchfulone
Overview
Notes
Download
Sounds good Martin, Please remember to work on vMix Title Designer also and add new features such as:
Drop Shadow effects
Blur Radius
Shadow dept
Please fix the font size selection, at the moment i have to highlight the default 64 size and change it by typing in a value.
Need to be more compatible with other font types.
Needs some basic animation such as slide in/out form the right of left or middle, fade, spin in, etc.
Even use similar animation in programs such as MS PowerPoint, we would be able to select these for each input.
And live update for our custom title in use via vMix Title Designer.
Bipin
#12 Posted : Thursday, September 5, 2013 9:08:50 AM(UTC)
Bipin
I love if it could support PNG sequence files for animation or Alpha Channel MOV file.
Regards
Bipin
sontoloyo
#13 Posted : Thursday, September 5, 2013 8:26:13 PM(UTC)
sontoloyo
Malaysia
Regards
Bipin
+1
#14 Posted : Thursday, September 5, 2013 10:15:12 PM(UTC)
vMix already supports alpha channel MOV files and PNG sequences.
Simply combine them with titles using the MultiView feature in vMix.
It must be stressed that this is a Title Designer, not a fully fledged compositing tool, which is what vMix is for.
Bipin on 9/7/2013(UTC), zul.ms on 11/22/2013(UTC)
#15 Posted : Monday, September 9, 2013 6:18:36 AM(UTC)
Beta 2 has been released below:
http://www.vmix.com.au/download/vMixTitleDesigner.exe
Changes
* Added DropShadow effect
* Added Font Size dropdown selector
* Designer can be set to 100%, 150% or fit to screen
* Manual positioning can be done through new X and Y properties
If you experience issues with this release, report them below.
You can alternatively download Beta 1 below:
http://www.vmix.com.au/download/vMixTitleDesignerBeta1.exe
thanks 3 users thanked admin for this useful post.
Adriankey4 on 9/9/2013(UTC), watchfulone on 9/9/2013(UTC), madness on 2/19/2014(UTC)
ask
#16 Posted : Monday, September 9, 2013 7:28:53 AM(UTC)
ask
Nice work Martin. Thanks. I love it's simplicity. Would it be possible to add .png as an option to save the file? I can see it being really usefull in building a title sequence very quickly. At the beginning of a basketball game for example to list the starting players.
Regards
Adriankey4 on 9/24/2013(UTC)
watchfulone
#17 Posted : Monday, September 9, 2013 11:09:46 AM(UTC)
watchfulone
Changes
Martin when I say you are the boss, I mean you are the boss
Well done Martin love it love it, God bless.
Damn2Good4U
#18 Posted : Monday, September 9, 2013 12:44:38 PM(UTC)
Damn2Good4U
The man called Martin never disappoint his followers and clients..
Just do not have anything more to say about you than to buttress @Watchfulone point that you are the BOSS...
kudos and God bless you real good.
Bardos
#19 Posted : Tuesday, September 17, 2013 8:33:49 AM(UTC)
Bardos
Groups: Guests
Hi Martin, for some unknown reason I am unable to download the file....don't know why...I keep getting a time out message, or Google can not connect to the site..
Any help would be appriciated
Adriankey4
#20 Posted : Monday, September 23, 2013 3:40:49 PM(UTC)
Adriankey4
Jamaica
Hi Martin.
I understand that but I've trying importing a graphics from A.E. in a mov file (which is a logo motion in alpha channel and is complete) but it is not importing.
How should i import it in the software?
Adrian
Similar Topics
About vMix Title Designer (Feature Requests)
by 540144407 5/14/2017 2:50:19 AM(UTC)
Roboto Font in Vmix Title designer (General Discussion)
by mburel1980 8/19/2016 2:17:33 PM(UTC)
VMix Title Designer not working (General Discussion)
by waynew 12/6/2014 1:04:29 PM(UTC)
vMix Title Designer Upgrades (Feature Requests)
by watchfulone 9/8/2013 8:13:24 PM(UTC)
vMix Title Designer - Coming Soon (General Discussion)
by admin 8/11/2011 2:10:04 AM(UTC)
3 Pages123>
