waldron18
#1 Posted : Friday, October 5, 2018 9:48:56 AM(UTC)
waldron18
I've just started getting an issue with vMix crashing. I open my preset which I have been using for our show every week for about a year. Everything loads fine and plays out without issues.
The problem is occurring when I click on the Record cog (settings) icon down the bottom. vMix just sits there and thinks about it for about 30 seconds and then crashes. When I reopen the preset it may or may not do it again.
My computer has plenty of capacity... i9, 32GB ram, m.2 SSD's etc etc.
Any thoughts?
#2 Posted : Friday, October 5, 2018 12:18:31 PM(UTC)
Was thanked: 4642 time(s) in 1604 post(s)
Please drop us an email to info@vmix.com.au as we will probably need to diagnose over TeamViewer.
There seems to be a rare issue that is the combination of a recent Windows update and the Blackmagic MJPEG codec.
We can't replicate it on our systems so are hoping we can run the diagnostics on a system where this occurs.
Thanks,
matteoarrigone
#3 Posted : Friday, October 5, 2018 4:39:50 PM(UTC)
matteoarrigone
We have the same problem. So, the "solution" we have found is to save before entering the rec option. When we click on the rec settings it crashes. We re-open it and then we can click on the rec settings without any crash.
We have i7, 16gb ram and gtx1060.
Matteo
#4 Posted : Friday, October 5, 2018 10:11:09 PM(UTC)
I think this issue is related to an installed codec that does not correctly support 64bit.
When opening the recording setup for the first time, vMix will open each codec installed on the system
to retrieve information about it.
If that codec has a 64bit memory bug, it will crash if vMix is already using a lot of memory, such as
with a preset open with a large number of inputs.
To track down the offending codec and disabling it (it is likely not even used by vMix) try the steps below:
1. Download Autoruns
https://docs.microsoft.c...rnals/downloads/autoruns
2. Run Autoruns by right clicking it and selecting Run as Administrator
3. Click the Codecs tab
4. Look through the list under "HKLM\Software\Microsoft\Windows NT\CurrentVersion\Drivers32"
You can try disabling each one by one (uncheck the box next to it to temporarily disable).
Then start vMix again each time to test until the problem codec is found.
For example the ajavfw codec has this issue and can be safely disabled as it is no longer included with the latest AJA drivers.
If you are able to identify a codec causing the problem, please post information about it here so we can block
it in the next vMix update.
Thanks,
prass on 10/10/2018(UTC)
prass
#5 Posted : Tuesday, October 9, 2018 11:43:14 PM(UTC)
prass
Was thanked: 3 time(s) in 1 post(s)
Hello!
Disable this fix my problem.
waldron18
#6 Posted : Wednesday, October 10, 2018 8:43:56 AM(UTC)
waldron18
I have done a recent windows update and now I can't replicate the issue. No not sure what's going on here... I've got another show tonight so I'll see what happens.
waldron18
#7 Posted : Wednesday, October 10, 2018 9:12:28 AM(UTC)
waldron18
I spoke too soon. It just did it then. I'm disabling the codecs now to try and work out which one it is on my machine.
natzakaria
#8 Posted : Saturday, October 13, 2018 4:31:28 PM(UTC)
natzakaria
Had a vMix crash - soft of - while going LIVE.
Stream was going fine for about 45 minutes.
Tried editing Title then it just froze but didnt freeze the stream - just that I cant do anything else.
Was lucky that camera switching was via DataVideo so the show continued.
Which in the autorun should I disable?
guztavo
#9 Posted : Thursday, October 18, 2018 8:57:26 AM(UTC)
guztavo
Hi!
Next saturday i have a live sports broadcast for TV... should i be worried?
Is there any way to check stability of my system?
Thanks in advance.
Regards.
#10 Posted : Thursday, October 18, 2018 2:31:38 PM(UTC)
This is a rare issue that only occurs on systems with some faulty codecs installed
and in presets using more than 4GB of memory.
For most users it should not be something you need to worry about.
Similar Topics
vMix Crashing Issue - avcodec (General Discussion)
by Gigabrain 4/15/2025 3:48:26 AM(UTC)
vMix Crashing - Please Help (Resolved) (General Discussion)
by MrMagoo 10/11/2023 9:59:55 AM(UTC)
vMix Crashing with no error or warning (General Discussion)
by cjudge05 12/6/2022 1:04:13 AM(UTC)
Vmix crashing with weird error (General Discussion)
by kahjah 4/1/2021 3:06:59 AM(UTC)
Anyone experiencing VMIX Crashing during VMIXCall? (vMix Call)
by Ryan Salazar 11/9/2020 7:09:15 AM(UTC)
vMix crashing w/o event log with BirdDog Mini (NDI)
by FID_Productions 9/15/2020 5:55:25 PM(UTC)
VMix Crashing with TCP Pull (General Discussion)
by jvphobic 8/13/2018 8:13:06 PM(UTC)
vMix crashing during live streaming, regular display driver crash during normal use. (General Discussion)
by Napamike 3/11/2016 3:03:33 PM(UTC)
vmix crashing graphics adapter (Hardware Compatibility)
by ratcast 3/5/2013 4:59:01 PM(UTC)
