Paul-PE1RJV
#1 Posted : Tuesday, September 25, 2018 4:45:42 AM(UTC)
Paul-PE1RJV
I have four Deltacast DELTA-hd-e 11 cards but am struggling to get them to work with vMix.
They are on the hardware compatibility list and drivers are loaded in Windows, but I cannot select them either as input nor output in vMix.
Is there anything I am missing ?
#2 Posted : Tuesday, September 25, 2018 5:24:36 AM(UTC)
Was thanked: 4727 time(s) in 1619 post(s)
Have you tried installing the "Directshow filters redist" on this page?
https://www.deltacast.tv.../sdi-cards/delta-hd-e-11
Paul-PE1RJV
#3 Posted : Tuesday, September 25, 2018 5:46:12 AM(UTC)
Paul-PE1RJV
Yes I have installed the drivers from the VideoMaster Redist package and installed the WindowsDirectShow Filters Redist afterwards.
#4 Posted : Tuesday, September 25, 2018 7:39:59 AM(UTC)
If both are installed and no options show up in vMix under Add Input -> Camera
after restarting the computer, best to contact Deltacast for further investigation as it looks like the card is not being detected by the system.
Paul-PE1RJV
#5 Posted : Tuesday, September 25, 2018 9:47:51 AM(UTC)
Paul-PE1RJV
Thanks Martin, will do that.
I will try some more testing this evening.
Is there a (debug) log in vMix that shows what cards are detected ?
It's probably a good idea to have some information for the Deltacast guys as well.
Paul
Paul-PE1RJV
#6 Posted : Wednesday, September 26, 2018 8:14:19 AM(UTC)
Paul-PE1RJV
After some more playing around, completely removing and uninstalling everything I managed to get it to work by using the driver that is in the "Directshow filters redist" package.
So I did not use the "VideoMaster Redist" package any more.
Maybe this helps other people using Deltacast cards.
Paul
Joeboe
#7 Posted : Monday, February 15, 2021 9:34:15 PM(UTC)
Joeboe
Paul
How did you do that,....I tried all methods I can remember, but nothing works, and which version driver package did you use....
Thank you
Joeboe
#8 Posted : Tuesday, April 20, 2021 12:27:39 AM(UTC)
Joeboe
Does vMix 23 and 24 support Deltacast Delta-hd-e cards, because I can not get my cards to work on my systems .. they show up in Device Manager, but not seen in vMix
