Joined: 9/25/2018(UTC) Posts: 4  Location: Netherlands
I have four Deltacast DELTA-hd-e 11 cards but am struggling to get them to work with vMix. They are on the hardware compatibility list and drivers are loaded in Windows, but I cannot select them either as input nor output in vMix. Is there anything I am missing ?
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Yes I have installed the drivers from the VideoMaster Redist package and installed the WindowsDirectShow Filters Redist afterwards.
If both are installed and no options show up in vMix under Add Input -> Camera after restarting the computer, best to contact Deltacast for further investigation as it looks like the card is not being detected by the system.
Martin vMix
Thanks Martin, will do that. I will try some more testing this evening. Is there a (debug) log in vMix that shows what cards are detected ? It's probably a good idea to have some information for the Deltacast guys as well.
Paul
After some more playing around, completely removing and uninstalling everything I managed to get it to work by using the driver that is in the "Directshow filters redist" package. So I did not use the "VideoMaster Redist" package any more. Maybe this helps other people using Deltacast cards.
Paul
Originally Posted by: Paul-PE1RJV  After some more playing around, completely removing and uninstalling everything I managed to get it to work by using the driver that is in the "Directshow filters redist" package. So I did not use the "VideoMaster Redist" package any more. Maybe this helps other people using Deltacast cards.
Paul How did you do that,....I tried all methods I can remember, but nothing works, and which version driver package did you use.... Thank you
Does vMix 23 and 24 support Deltacast Delta-hd-e cards, because I can not get my cards to work on my systems .. they show up in Device Manager, but not seen in vMix
