peterbus8699
#1 Posted : Friday, August 31, 2018 4:14:04 PM(UTC)
peterbus8699
Can someone let me know how to record overlay on a video .
I have tried everything but the recording just shows the video without the overlay ( if this makes sense) .
I know it’s a setting problem but I tried all I can to no avail, thanks in advance, pete
#2 Posted : Friday, August 31, 2018 6:17:15 PM(UTC)
Maybe reading the manual can help for such basic questions.
Trying without understanding is a solution that only brought you here I guess
https://www.vmix.com/help21/
vMix team also provides plenty of videos that cover all aspect of the software use
https://www.youtube.com/user/vmixcomau
Happy vMixing!
Guillaume
peterbus8699
#3 Posted : Saturday, September 1, 2018 2:16:36 AM(UTC)
peterbus8699
Happy vMixing!
Guillaume
Thanks for trying to help ( I think) , I have studied the manual but no matter the settings I cannot get the overlay , whether animated or static to record over the video, it had nothing to to with trying without understanding, but thanks anyway.
elvis55
#4 Posted : Saturday, September 1, 2018 2:45:45 AM(UTC)
elvis55
Switzerland
Hallo
overlay no rec
Gruss
#5 Posted : Saturday, September 1, 2018 4:00:46 AM(UTC)
Overlays are streamed and recorded BY DEFAULT !!!
Reset all your settings
Guillaume
#6 Posted : Sunday, September 2, 2018 1:11:07 AM(UTC)
@ peterbus8699
Sounds to me like you have them all turned off in the Output 1 settings.
Go to Settings ===> Outputs/NDI ===> Output 1 ===> Overlays column dropdown ===> Turn All On
Similar Topics
Problem with GT titles not rendering on overlay (GT)
by MarcoM 10/15/2026 10:15:34 PM(UTC)
Overlay on External Output (General Discussion)
by buntonn 6/19/2026 9:38:59 PM(UTC)
Overlay Input in/out onto two seperate inputs at same time (General Discussion)
by KNTR 3/6/2026 11:06:18 PM(UTC)
Title in overlay conundrum (GT)
by TL68 3/3/2026 9:31:41 PM(UTC)
The ability for Preset Bundles to also save overlay and audio output settings (Feature Requests)
by kuuminsh 2/11/2026 11:10:19 PM(UTC)
Overlay off during transition (General Discussion)
by televisiontim 1/8/2026 11:03:07 AM(UTC)
Multiviewer should reflect tally state of an Overlay input (Feature Requests)
by KerryDP 12/9/2025 6:10:26 AM(UTC)
Overlay with Fixed size cam inputs (General Discussion)
by a.roller4u 12/5/2025 2:54:08 AM(UTC)
Overlay Off if Title Field empty (General Discussion)
by adambou 12/2/2025 10:46:31 AM(UTC)
Last used overlay indicator (similar to active input on overlay) (Feature Requests)
by RezChurch 10/20/2025 4:38:08 AM(UTC)
Overlay on different mix not program (Feature Requests)
by jp1261987 10/9/2025 9:44:38 PM(UTC)
Overlays on Mix Inputs (Beta Discussion)
by Streamverse.tv 8/30/2025 7:49:09 AM(UTC)
New Overlays 5-8 Importing Stinger Settings From V28, Unable To Remove (FIXED) (Beta Discussion)
by kmedia 8/21/2025 3:21:06 AM(UTC)
Overlay 5-8 Activators (FIXED) (Beta Discussion)
by Dist 8/17/2025 8:41:45 PM(UTC)
Missing new Overlay/Transition layers for Input Mouse Click action (FIXED) (Beta Discussion)
by ryxyz 8/16/2025 11:52:08 PM(UTC)
Overlays cannot be activated by center buttons (Beta Discussion)
by ryxyz 8/16/2025 11:47:04 PM(UTC)
How can I use BitFocus Companion App to look at JSON data and trigger an Input Overlay (3rd Party Software and Development)
by daver89 8/16/2025 4:24:38 AM(UTC)
Overlay option to disable automatic transition (Feature Requests)
by WebcastFlorida 7/10/2025 10:57:14 PM(UTC)
more overlay chanels (Feature Requests)
by JoKo 7/10/2025 12:37:54 AM(UTC)
2 request - NDI|HX3 and NDI Overlays (Feature Requests)
by mikeborschow 7/5/2025 6:25:14 AM(UTC)
VMIx 28 XML API VirtualSet missing <overlay> (General Discussion)
by Dragon 6/15/2025 2:34:02 AM(UTC)
Camera Overlays (Feature Requests)
by calamityjane 6/5/2025 2:20:09 AM(UTC)
Suggestion for vMix: Separate overlay slots for each mix (Feature Requests)
by gugacdb 5/30/2025 3:37:03 AM(UTC)
Changing Overlays in vMix 4K (General Discussion)
by KnoxTrinity 5/19/2025 12:45:18 AM(UTC)
Overlay Out Title Animation when on a Layer (Feature Requests)
by knbPixels 5/17/2025 6:32:25 AM(UTC)
Overlay Shortcuts (General Discussion)
by Cyberkorr 4/27/2025 7:36:36 AM(UTC)
Companion + Overlay not working version 28.0.0.39 (General Discussion)
by fabfab10 3/18/2025 9:42:24 PM(UTC)
Issue with Overlay 1 (General Discussion)
by Gary2theO 3/6/2025 1:45:22 AM(UTC)
2 seperate outputs w/ 2 seperate overlay channels (General Discussion)
by klegault 2/1/2025 1:30:10 AM(UTC)
How to get a generated overlay in a window in vMix? (General Discussion)
by Mari 1/2/2025 6:52:41 PM(UTC)
