Joined: 4/27/2025(UTC) Posts: 1  Location: Pennsylvania
Is there a way to create a shortcut that will advance the "Title Preset" in an overlay for JUST the active overlay?
I currently have 3-4 different shortcuts set up for each numbered overlay.
A single button to advance the active overlay and not all presets would be great.
thank you!
Hi. Can you please explain a little more what you need to do? For example you have "Mytitle1.gtzip", "Mytitle2.gtzip", "Mytitle3.gtzip" and in current moment "Mytitle1.gtzip" is active on overlay1 and then you need "Mytitle2" to press a button and go to overlay1 or if "mytitle3" is active on overlay3 to press the same button and "Mytitle1" go also to overlay 3?
Joined: 11/27/2023(UTC) Posts: 136  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
Originally Posted by: Cyberkorr  Is there a way to create a shortcut that will advance the "Title Preset" in an overlay for JUST the active overlay?
thank you! yes you can ... in the title you are using for that overlay, when you edit that title, click on the '+' at the bottom and vmix will add it there ... then you edit again, and do the same thing to create as many titles as you need ... then go to settings in the vMix interface (top right hand of the UI), choose 'shortcuts', select a key on the keyboard you are not using as any shortcuts, click on 'FIND', hold and select the key you will be using for advancing, and assign the appropriate function for that title input. repeat the steps and select another key for going back,(previous text),...I have been doing this from the time I had vMix, and that was very long ago..... from version 10, or before...
