Thanks: 13 times Was thanked: 1 time(s) in 1 post(s)
Vmix 10 has the same old title templates sadly,but seems to have changed the layout.thanx
martin could you add divider image to scroll tickers ????? so that we could add logos to the news bar?
Dear Martin,
could you please add vMix' version to the status output when calling api without parameters? This would help my (and others') application to decide wether it is talking to the right version of vMix and, if the version is too old, tell the user. My application relies on the new api functions and won't work with vMix 9 and older, so i'd like to check on start.
Web-API, Input=936DA01F-9ABD-4d9d-80C7-02AF85C822A8 (or some other guid)
It seems, most functions default to input "preview" whenever the given GUID is not found. I'd prefer the functions to fail / do nothing if the given parameter is a non existent guid (that is: it's a formally valid guid, but it doesn't exist). Defaulting to preview is fine though when there's no input specified or the given parameter is not a guid (e.g. an input number).
In other words: please make it so that vMix just ignores all commands that contain non-existant guids! This way there will be no undesired effects if a user manually closes inputs while vMixScheduler is still running.
One more thing i found: "blank" input seems to be locked to a 4:3 aspect; e.g. if output is 720p and vmix is transitioning from a 16:9 clip to the blank input there are borders at the left and right side:
Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Yaamin wrote:martin could you add divider image to scroll tickers ????? so that we could add logos to the news bar? +1
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Just a reminder everyone that new features should not be requested here. Bugs and minor updates can be posted here but everything else should go in the Feature Requests forum.
macjaeger,
The next update will fix the default to preview functionality in the API and display the version in the XML information. Out of curiosity, do you currently look for the "vmix" root element when parsing the XML? I would like to change it to "xml" for the final release, but only if it won't impact any existing applications.
Quote:Out of curiosity, do you currently look for the "vmix" root element when parsing the XML? I would like to change it to "xml" for the final release, but only if it won't impact any existing applications. Yepp, i'm parsing the XML, looking for "vmix/input/inputs" nodes - but that can be changed in a jiffy, so feel free to transition to "xml" anytime. I can even add code to look for both until then, so there won't be any problems. Thank you for your continuos support of third party developement!
Dear Martin, is it possible extend the API? 1/ display name of loaded preset 2/ load a existing preset by API calls
Bests, Cybermouse
Looking at shortcuts and the list of keys, there are some double entries (like "Page Up", "Next", "PrintScreen", ...) and one or some are missing (like "Page Down"). So it's impossible to configure the "Page Down" key that is used by USB-Presenters. I think it's the same with V9 and V10.
Yaamin wrote:martin could you add divider image to scroll tickers ????? so that we could add logos to the news bar? +1 but i think this should be in the Feature Requests
Thanks ovinas for showing that, I've mentioned it before but have chosen to work around rather than push for a fix, but I think it needs fixing. I would also perhaps like to see a reference chart or graphic in the wiki that would certainly help with some of the more obscure key references since I have no idea what they are.
Ovinas,
The "next" option is Page Down.
Martin vMix
You have been a member since:: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Currently playing with 10.0.0.38 and no matter what overlay settings i use on the output settings all overlays always show on both the full-screen and the external/record, my plan was to use the overlays and full screen out to drive studio set plasma displays and having overlays 1 & 2 only on the full-screen , 1 having a holding graphic for the plasmas and 2 for any VT's and then just fade the vt to main mix when i want it fullscreen on the record/tx. and leaveing overlay 3&4 for only rec/tx for on screen graphics names ect
is this is bug or am i doing something wrong?
cheers
Ian
@ Martin Is it safe to assume that the duplicate key selections (Page up, Next and Print Screen) refer to said keys and are simply "typo's" in the window selection screen?
Ian,
There are currently a few bugs in the separate overlay functionality that will be fixed soon.
IceStream,
The duplicate key selections are there because some keys have multiple names. However due to a bug in how the dropdown box is displayed, the second name does not appear.
Martin vMix
Hi All, An update to vMix 10 Preview is now available. (10.0.0.46) http://www.vmix.com.au/download/vmix10preview.exeChanges/Fixes: * Added two "Double Box" templates to Virtual Set * Added cog icon to audio mixer with new audio options: Gain and Channel selection * Improved audio meter accuracy * Fixed SetText bug * Virtual Set XML now supports RotateX, RotateY and RotateZ options for custom sets * NextItem, PreviousItem and SelectIndex API functions added * SelectedIndex was not loading correct video in List * Fixed issues with separate Overlay Outputs * Version added to API XML * API no longer defaults to Preview * Fixed blank aspect ratio * Removed duplicate/obsolete keys from dropdown list in shortcuts. PageUp/PageDown now correctly labelled Please report any bugs here. Thanks, Martin vMix
Rank: Guest
Groups: Guests
hi martin, found another issue... audio delay on external output does not work. this is the single obstacle that blocks me to not use v10 on our live production. regards, melody www.espiritosanto.cc
Melody, thanks for reporting that issue. An update (10.0.0.47) has been released below: http://www.vmix.com.au/download/vmix10preview.exeThis update includes: * Fixed Audio Delay setting issue in streaming * Fixed overflow bug in streaming window log Regards, Martin vMix
Rank: Guest
Groups: Guests
just to confirm... audio delay issue is now fixed. thank you very much martin, v10 will be used next weekend on our live stream services, mixing and recording at progressive 50fps and streaming progressive 25fps (simply amazing). best regards, melody www.espiritosanto.cc
