5 Pages<12345>
Yaamin
#41 Posted : Sunday, July 7, 2013 3:23:38 PM(UTC)
Yaamin
Vmix 10 has the same old title templates sadly,but seems to have changed the layout.thanx
Yaamin
#42 Posted : Sunday, July 7, 2013 4:49:56 PM(UTC)
Yaamin
martin could you add divider image to scroll tickers ????? so that we could add logos to the news bar?
macjaeger
#43 Posted : Sunday, July 7, 2013 5:14:18 PM(UTC)
macjaeger
Dear Martin,
could you please add vMix' version to the status output when calling api without parameters? This would help my (and others') application to decide wether it is talking to the right version of vMix and, if the version is too old, tell the user. My application relies on the new api functions and won't work with vMix 9 and older, so i'd like to check on start.
macjaeger
#44 Posted : Sunday, July 7, 2013 5:51:27 PM(UTC)
macjaeger
Web-API, Input=936DA01F-9ABD-4d9d-80C7-02AF85C822A8 (or some other guid)
It seems, most functions default to input "preview" whenever the given GUID is not found. I'd prefer the functions to fail / do nothing if the given parameter is a non existent guid (that is: it's a formally valid guid, but it doesn't exist). Defaulting to preview is fine though when there's no input specified or the given parameter is not a guid (e.g. an input number).
In other words: please make it so that vMix just ignores all commands that contain non-existant guids! This way there will be no undesired effects if a user manually closes inputs while vMixScheduler is still running.
macjaeger
#45 Posted : Sunday, July 7, 2013 5:56:40 PM(UTC)
macjaeger
One more thing i found:
"blank" input seems to be locked to a 4:3 aspect; e.g. if output is 720p and vmix is transitioning from a 16:9 clip to the blank input there are borders at the left and right side:
sontoloyo
#46 Posted : Monday, July 8, 2013 2:12:27 AM(UTC)
sontoloyo
Malaysia
+1
#47 Posted : Monday, July 8, 2013 3:08:11 AM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Just a reminder everyone that new features should not be requested here.
Bugs and minor updates can be posted here but everything else should go in the Feature Requests forum.
macjaeger,
The next update will fix the default to preview functionality in the API and display the version in the XML information.
Out of curiosity, do you currently look for the "vmix" root element when parsing the XML?
I would like to change it to "xml" for the final release, but only if it won't impact any existing applications.
sontoloyo on 7/8/2013(UTC), Yaamin on 7/8/2013(UTC)
macjaeger
#48 Posted : Monday, July 8, 2013 7:39:14 AM(UTC)
macjaeger
Yepp, i'm parsing the XML, looking for "vmix/input/inputs" nodes - but that can be changed in a jiffy, so feel free to transition to "xml" anytime. I can even add code to look for both until then, so there won't be any problems.
Thank you for your continuos support of third party developement!
cybermouse
#49 Posted : Tuesday, July 9, 2013 7:19:04 AM(UTC)
cybermouse
Dear Martin, is it possible extend the API?
1/ display name of loaded preset
2/ load a existing preset by API calls
Bests, Cybermouse
ovinas
#50 Posted : Tuesday, July 9, 2013 1:12:45 PM(UTC)
ovinas
Looking at shortcuts and the list of keys, there are some double entries (like "Page Up", "Next", "PrintScreen", ...) and one or some are missing (like "Page Down"). So it's impossible to configure the "Page Down" key that is used by USB-Presenters. I think it's the same with V9 and V10.
Damn2Good4U
#51 Posted : Tuesday, July 9, 2013 4:48:36 PM(UTC)
Damn2Good4U
+1 but i think this should be in the Feature Requests
#52 Posted : Tuesday, July 9, 2013 9:14:30 PM(UTC)
Thanks ovinas for showing that, I've mentioned it before but have chosen to work around rather than push for a fix, but I think it needs fixing. I would also perhaps like to see a reference chart or graphic in the wiki that would certainly help with some of the more obscure key references since I have no idea what they are.
#53 Posted : Tuesday, July 9, 2013 10:14:09 PM(UTC)
Ovinas,
The "next" option is Page Down.
Henny
#54 Posted : Friday, July 12, 2013 6:07:45 PM(UTC)
Henny
Currently playing with 10.0.0.38 and no matter what overlay settings i use on the output settings all overlays always show on both the full-screen and the external/record, my plan was to use the overlays and full screen out to drive studio set plasma displays and having overlays 1 & 2 only on the full-screen , 1 having a holding graphic for the plasmas and 2 for any VT's and then just fade the vt to main mix when i want it fullscreen on the record/tx. and leaveing overlay 3&4 for only rec/tx for on screen graphics names ect
is this is bug or am i doing something wrong?
cheers
Ian
#55 Posted : Friday, July 12, 2013 11:34:27 PM(UTC)
@ Martin
Is it safe to assume that the duplicate key selections (Page up, Next and Print Screen) refer to said keys and are simply "typo's" in the window selection screen?
#56 Posted : Saturday, July 13, 2013 12:49:38 AM(UTC)
Ian,
There are currently a few bugs in the separate overlay functionality that will be fixed soon.
IceStream,
The duplicate key selections are there because some keys have multiple names.
However due to a bug in how the dropdown box is displayed, the second name does not appear.
#57 Posted : Saturday, July 13, 2013 8:27:35 AM(UTC)
Hi All,
An update to vMix 10 Preview is now available. (10.0.0.46)
http://www.vmix.com.au/download/vmix10preview.exe
Changes/Fixes:
* Added two "Double Box" templates to Virtual Set
* Added cog icon to audio mixer with new audio options: Gain and Channel selection
* Improved audio meter accuracy
* Fixed SetText bug
* Virtual Set XML now supports RotateX, RotateY and RotateZ options for custom sets
* NextItem, PreviousItem and SelectIndex API functions added
* SelectedIndex was not loading correct video in List
* Fixed issues with separate Overlay Outputs
* Version added to API XML
* API no longer defaults to Preview
* Fixed blank aspect ratio
* Removed duplicate/obsolete keys from dropdown list in shortcuts. PageUp/PageDown now correctly labelled
Please report any bugs here.
Thanks,
kayllastudio on 7/13/2013(UTC)
melody
#58 Posted : Saturday, July 13, 2013 12:16:28 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
found another issue... audio delay on external output does not work.
this is the single obstacle that blocks me to not use v10 on our live production.
regards,
melody
www.espiritosanto.cc
#59 Posted : Monday, July 15, 2013 11:09:40 AM(UTC)
Melody, thanks for reporting that issue.
An update (10.0.0.47) has been released below:
This update includes:
* Fixed Audio Delay setting issue in streaming
* Fixed overflow bug in streaming window log
melody
#60 Posted : Tuesday, July 16, 2013 10:47:09 AM(UTC)
Rank: Guest
Groups: Guests
just to confirm... audio delay issue is now fixed.
thank you very much martin, v10 will be used next weekend on our live stream services, mixing and recording at progressive 50fps and streaming progressive 25fps (simply amazing).
best regards,
melody
Guest (10)
5 Pages<12345>
