Joined: 2/23/2018(UTC) Posts: 17 Location: Lewisburg PA
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Seems that vMix is missing an activator for Multicorder. Would be great if that added that as an option. Also, perhaps also a BUTTON LATCH (to keep a color solid) in addition to the button BUTTON PRESS which gives just a momentary button color change
Joined: 7/9/2016(UTC) Posts: 18 Location: Williamston Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
Joined: 11/23/2016(UTC) Posts: 330 Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
+1 Rowby. Apparently also missing for Record and Stream -- at least I can't find them....
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
gotscottgreen wrote: Also, perhaps also a BUTTON LATCH (to keep a color solid) in addition to the button BUTTON PRESS which gives just a momentary button color change +1 Makes it easier to check which clips/commercials have already been played
Joined: 9/13/2016(UTC) Posts: 112 Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
