Joeboe
#1 Posted : Monday, January 29, 2018 4:51:58 AM(UTC)
Joeboe
Hi guys, I do not know what has gone wrong.....I was using a PC with vMix 20.0.0.42, and it worked great with NDI inputs from a laptop using 19.xxx but today I set up for a function, and found that the laptop shows up in the NDI/Capture under the inputs, but there is no video ...just a black screen.....I tried the other way, to see if the problem was on the desktop, but that did the same....the desktop of the desktop PC showed, but just black on the inputs.....I installed the desktop capture on another laptop that does not have vMix installed, and got a screen capture...worked great, but not on any that has vMix on it.....Need help.....it worked all along, but now it does not
thanks 1 user thanked Joeboe for this useful post.
adziebart on 1/31/2018(UTC)
adziebart
#2 Posted : Wednesday, January 31, 2018 12:38:39 PM(UTC)
adziebart
I am experiencing this as well.
I updated to version 20.0.0.51 and my Cameras which were running on NDI are no longer connecting to my vMix.
Local Desktop capture on NDI still works properly.
I verified I can connect to all NDI cameras via the Newtek "Video Monitor".
What Happened?
Barney Box Lane
#3 Posted : Thursday, February 1, 2018 10:01:19 AM(UTC)
Barney Box Lane
usually a mismatch is resolution and fps, check they're both exactly the same output
Similar Topics
vMix 29.0.0.49 NDI Input locking up (General Discussion)
by Roy Sinclair 10/19/2026 12:04:49 AM(UTC)
vMix video/audio stuttering via NDI from Dinesat 12 Visual (NDI)
by Gabriel502 9/11/2026 5:43:57 AM(UTC)
NDI input is black (NDI)
by Abayomitsn 8/23/2026 11:07:03 PM(UTC)
New vMix build 5 NDI 2 SDI streaming (Systems)
by alefello 8/18/2026 12:10:10 AM(UTC)
NDI and Video inputs blanking out. (General Discussion)
by boris9831 7/14/2026 7:37:23 AM(UTC)
NDI and OMT on vMix both running (OMT - Open Media Transport)
by Wouter 7/10/2026 12:44:33 AM(UTC)
Ability to set specific NDI port for Outputs (Feature Requests)
by jet 6/24/2026 7:39:23 PM(UTC)
Hardware Converter: SDI to NDI and DANTE Ethernet Card (Hardware Compatibility)
by blopes 6/10/2026 7:40:05 AM(UTC)
Excessive Source Drops, Render Drops, and Sync Issues with PTZOptics Studio 4K via NDI in vMix 29 (NDI)
by Matts887 6/2/2026 10:38:07 AM(UTC)
vMix Sees NDI Cameras, But Black Screen Using Them For Replay? (NDI)
by JohnDoe415 5/15/2026 8:59:28 PM(UTC)
how to force NDI HX3 capture (NDI)
by h2video.nl 4/8/2026 4:13:39 AM(UTC)
NDI hangs up (NDI)
by brianconverse 4/1/2026 6:45:00 AM(UTC)
Zoom Caller NDI OUT (Feature Requests)
by JDroadie 3/28/2026 1:04:52 AM(UTC)
Ptz NDI with vmix leggings (General Discussion)
by Almeida 3/26/2026 7:32:19 AM(UTC)
NDI routing on specific NIC (NDI)
by florinvg 3/8/2026 3:39:07 AM(UTC)
Remote Control for BirdDog Play & NDI Studio Monitor (iOS & Android) (NDI)
by youcci 2/18/2026 8:32:04 PM(UTC)
Source NDI view (Feature Requests)
by Srivelles 2/11/2026 6:13:15 PM(UTC)
NDI HX support for Output (Feature Requests)
by inquattro 2/4/2026 7:20:28 AM(UTC)
Birddog XL Ultra Full NDI Crashes vMix (NDI)
by VVEPBrian 1/27/2026 9:48:11 AM(UTC)
Pulling Multiple Screen Shares as NDI Feeds (NDI)
by knbPixels 1/23/2026 4:37:16 AM(UTC)
NDI 6.x Discovery support (Feature Requests)
by fgolman 1/22/2026 2:56:09 PM(UTC)
NDI Audio Capture only (NDI)
by waxxel 1/14/2026 6:16:25 AM(UTC)
Need help with NDI into vMix via Tailscale (NDI)
by knbPixels 1/14/2026 2:46:15 AM(UTC)
Selection for image when loss of NDI stream (Feature Requests)
by fgolman 1/9/2026 5:50:08 AM(UTC)
NDI inputs 60 fps, Stream output 29.97 (NDI)
by Juke_Box 12/24/2025 7:58:29 AM(UTC)
NDI Output to Rodecaster Video (NDI)
by fcvideo 12/8/2025 4:29:10 AM(UTC)
NDI Input Freeze (NDI)
by Thomas K 11/14/2025 4:27:55 AM(UTC)
Turning on NDI from Streamdeck/Companion (NDI)
by fcvideo 11/11/2025 11:43:55 PM(UTC)
2 vmix instances to make more zoom guests available via NDI on the network? (General Discussion)
by mairginter@hotmail.com 10/28/2025 4:35:24 AM(UTC)
Go NDI or stick with SDI when updating to vMix? (NDI)
by TL68 9/30/2025 12:24:43 AM(UTC)
