brianconverse
#1 Posted : Wednesday, April 1, 2026 6:45:00 AM(UTC)
brianconverse
I'm using WorshipTools to present lyrics on the screens in the room via HDMI. I also send lyrics on the lower thirds to another monitor that I use NDI to pull into vMix. My NDI connection for lyrics to vMix hangs up every Sunday and I have to reset the connection to get it to go again.
Everything I've read points to network latency issues. The computers are on the same subnet. I've run ping to see if I can see any latency when it happens and I really don't see anything obvious.
Any help or thoughts on this would be appreciated.
miro_lee
#2 Posted : Wednesday, April 1, 2026 7:37:58 PM(UTC)
miro_lee
Italy
It freezes even in NDI studio monitor on the Vmix machine?
brianconverse
#3 Posted : Wednesday, April 1, 2026 11:54:30 PM(UTC)
brianconverse
I'll have to check that. I didn't do that but I can. Let's say it's frozen in NDI studio monitor, what does that mean and why is that happening and how do I prevent this? If it's not frozen in NDI studio monitor, why is it frozen in vMix?
jip
#4 Posted : Monday, April 13, 2026 1:12:02 AM(UTC)
jip
Estonia
This sound close to the issue with which I'm having a dialogue with vMix support.
I'm seeing pretty random NDI source freeze with moderately complex projects. In the issue, NDI data would just freeze completely and if trying to change the NDI source or bandwidth settings from the input right-click menu, entire vMix UI will lockup completely despite FEIM enabled.
In my investigations I have noticed that using Sysinternals Process Explorer to restart the respective ndinode.exe process the NDI input can be restarted individually, which is currently not possible from vMix due to the complete lockup. The same effect might be possible from regular Task Manager processes.
Please report your findings here if also you have success with restarting/killing ndinode.exe process.
enasniog
#5 Posted : Thursday, April 16, 2026 5:05:56 AM(UTC)
enasniog
I was wondering if you had any progress on this issue? I have had the same issue where some bad NDI will cause the vMix UI to lock up when FEIM is turned on (if FEIM isn't turned on it will crash vMix completely). I did come to the same realization as you that using Windows Task Manager to kill the NDINode process will get it to start responding again.
If you have someone from support that is interested I have the logs from our latest crash and the relevant lines where things went wrong.
#6 Posted : Thursday, April 16, 2026 10:32:37 AM(UTC)
Was thanked: 4790 time(s) in 1644 post(s)
I would suggest contacting support directly:
https://www.vmix.com/contact-us.aspx
However, in all the cases we have seen, if even FEIM is failing it likely indicates a faulty computer rather than just a problematic NDI source.
jip
#7 Posted : Saturday, April 18, 2026 1:42:06 AM(UTC)
jip
Estonia
Thank you - I had contacted support already a while ago when first experiencing the symptoms.
/Sorry for thread hijacking
