Joined: 6/19/2017(UTC) Posts: 6  Location: Richland, WA, USA Thanks: 2 times
I have a virtual set we purchased from Virtual Setworks. I adjusted the zoom and Y position for a custom level but I cannot save it. Each time I load the set I must reset these values. I tried manually editing the XML file for the set, but it does not stay after re-loading vMix. I read the online tutorial that says to make the changes and use the "export" button to save the changes, but there is no "export" button.
How do I edit the positioning of the virtual set and save it?
So I figured it out. I found the "export" button under setup on the Virtual Set input next to the camera button. I also figured out that after editing the XML file for my custom zoom and position, I needed to reload the virtual set for the changes to take effect.
Originally Posted by: Brian E. Conklin  So I figured it out. I found the "export" button under setup on the Virtual Set input next to the camera button. I also figured out that after editing the XML file for my custom zoom and position, I needed to reload the virtual set for the changes to take effect. So the config file or xml file need to be edited manually?
Originally Posted by: DFNB  Originally Posted by: Brian E. Conklin  So I figured it out. I found the "export" button under setup on the Virtual Set input next to the camera button. I also figured out that after editing the XML file for my custom zoom and position, I needed to reload the virtual set for the changes to take effect. So the config file or xml file need to be edited manually? https://forums.vmix.com/...ve-virtual-set#post94686
tenho um cenário que comprei do 3dvirtualset.com mas na especificação diz assim, Atenção: Antes disso você precisa desligar a "Orientação automática" da câmera, o vídeo final deve ser composição horizontal. No sistema virtual (vMix; Tricaster), o sinal âncora ajustará automaticamente a orientação pelo Mapa UV.
no meu caso a pessoa ficou de lado no cenário a sombra também, alguém poderia me ajudar ?
