Brian E. Conklin
#1 Posted : Monday, June 19, 2017 11:59:56 AM(UTC)
Brian E. Conklin
I have a virtual set we purchased from Virtual Setworks. I adjusted the zoom and Y position for a custom level but I cannot save it. Each time I load the set I must reset these values. I tried manually editing the XML file for the set, but it does not stay after re-loading vMix. I read the online tutorial that says to make the changes and use the "export" button to save the changes, but there is no "export" button.
How do I edit the positioning of the virtual set and save it?
Brian E. Conklin
#2 Posted : Monday, June 19, 2017 12:17:57 PM(UTC)
Brian E. Conklin
So I figured it out.
I found the "export" button under setup on the Virtual Set input next to the camera button. I also figured out that after editing the XML file for my custom zoom and position, I needed to reload the virtual set for the changes to take effect.
DFNB
#3 Posted : Friday, July 9, 2021 6:18:46 PM(UTC)
DFNB
Malaysia
So the config file or xml file need to be edited manually?
#4 Posted : Friday, July 9, 2021 6:49:08 PM(UTC)
https://forums.vmix.com/...ve-virtual-set#post94686
Marciordj
#5 Posted : Friday, September 9, 2022 4:15:06 AM(UTC)
Marciordj
Brazil
tenho um cenário que comprei do 3dvirtualset.com mas na especificação diz assim,
Atenção: Antes disso você precisa desligar a "Orientação automática" da câmera, o vídeo final deve ser composição horizontal.
No sistema virtual (vMix; Tricaster), o sinal âncora ajustará automaticamente a orientação pelo Mapa UV.
no meu caso a pessoa ficou de lado no cenário a sombra também, alguém poderia me ajudar ?
