Bandit62
#1 Posted : Friday, January 27, 2017 12:02:02 PM(UTC)
Rank: Guest
Groups: Guests
I am trying to find a way to do a Merge, using the Merge effect, where I can have the incoming image not fill the entire screen (full screen). I want to have 3 inputs, where I can zoom 1 to a larger size, making the other 2 inputs smaller[img][/img]as in the examples attached
richardgatarski
#2 Posted : Friday, January 27, 2017 12:15:03 PM(UTC)
richardgatarski
There are some limitations in Merge as to how it handles the layering in the MultiView settings.
But you should be able to Merge between two inputs that have the layers configured as illustrated in your images. That is, one Input with the background Picture and three other Inputs in Layer 1, 2 and 3 - but differently positioned/sized.
Otherwise, try explaining in more details what does (not) happen when you Merge.
#3 Posted : Friday, January 27, 2017 12:39:29 PM(UTC)
@ Bandit62
If I understand you correctly, you'll require 7 Inputs for your set-up to be most effective (IMHO):
Backround Image
Image/Camera 1
Image/Camera 2
Image/Camera 3
Mix/Effect Multiview 1
M/E Multiview 2
M/E Multiview 3
Using the "Merge" transition between any of the Inputs should yield a Zoom effect, but as Richard states, there are some limitations based on the layering, which may not give the best results optically (upper most layer is the focus) so you are best to test different configurations to understand fully.
#4 Posted : Friday, January 27, 2017 12:39:38 PM(UTC)
I already did something like that using the virtual set empty preset. Maybe an option to try for you...
Bandit62
#5 Posted : Friday, January 27, 2017 12:59:51 PM(UTC)
Rank: Guest
Groups: Guests
What I want to achieve is exactly how the images look...I want to maintain backgrounds, or a looping video or graphic, 3 inputs as indicated in the images I posted. But when I use the Merge effect, I keep getting a full screen of the selected input...What I want to achieve, is a reduced image as in the examples...I want to avoid full screen of any of the inputs....Merge in vMix gives a full screen output...I want a cropped or scaled output.... I was wondering if there is a setting in the merge effct to give a scaled output....
richardgatarski
#6 Posted : Friday, January 27, 2017 1:17:06 PM(UTC)
richardgatarski
pls describe the Inputs (sources/multiview layers) that are in Preview and Output when you initiate the Merge.
Bandit62
#7 Posted : Friday, January 27, 2017 1:23:33 PM(UTC)
Rank: Guest
Groups: Guests
I use merge a lot with multiple inputs, and understand how it works....what I am trying to achieve, is a look like the images I posted...I do NOT want a merge to Full Screen, I want to keep the layout the same all the time, just swapping the inputs...
#8 Posted : Friday, January 27, 2017 1:38:38 PM(UTC)
@ Bandit62
Have you tried using 3 separate M/E Multiview Inputs (as I suggest above)?
I understand you don't want the "Fullscreen" Image, but you will still need the Fullscreen Input for the Special Effect to work properly, just be sure to never send it to Program Output.
For the effect you want, you need to transition between the 3 special effect Mutiview Inputs (what I call Mix Effect MultiViews), otherwise you are returning to the original "Fullscreen" Input.
Bandit62
#9 Posted : Friday, January 27, 2017 1:57:56 PM(UTC)
Rank: Guest
Groups: Guests
Think I figured out a way, not very sleek, but it does exactly what I wanted...took a little time to get nearly correct, but some tweeking will make it accurate, What I did was to create 2 virtual inputs, and rearrange the 3 inputs so that they will appear where and how I want them, and depending on which input I want to be the large image, I just select that 'Virtual input', and use the 'Merge' transition, and it works ok...just have to play with the speed to get it looking smooth.
richardgatarski
#10 Posted : Friday, January 27, 2017 2:30:37 PM(UTC)
richardgatarski
jolly good :)
#11 Posted : Friday, January 27, 2017 6:57:39 PM(UTC)
@ Bandit62
Yes, your "Virtual Inputs" are the "M/E Multiview" Inputs I referenced (there are multiple ways of achieving this, I'm glad you figured one of them out)...
Similar Topics
Smoothing the animation of merge transitions (General Discussion)
by Utocate 12/12/2025 9:21:58 AM(UTC)
Can Merge be improved? (General Discussion)
by knbPixels 10/3/2025 9:55:07 AM(UTC)
Merge works on mix 2 but merge transition out cuts (General Discussion)
by gostreamworks 9/18/2025 9:57:54 PM(UTC)
New Merge parially working (General Discussion)
by michaelthomasbrennan 8/18/2025 9:24:01 PM(UTC)
Merge between source and its virtual input when flatten layered (Feature Requests)
by semenov_nick_1990 6/19/2025 7:40:49 PM(UTC)
merge presets including their local shortcuts/activators (Feature Requests)
by mjehnichen 2/13/2025 9:58:29 AM(UTC)
Merge anomalies with Flattened Layers, PTZ and Layers (Beta Discussion)
by Highway20Productions 1/16/2025 3:42:06 AM(UTC)
Flatten Layers and merge (Beta Discussion)
by dark_ata 11/28/2024 11:02:43 PM(UTC)
Merge Transition Preview (Feature Requests)
by kmedia 10/12/2024 1:50:47 AM(UTC)
need a much slower merge! (General Discussion)
by grDancer 11/22/2023 2:09:13 AM(UTC)
merge? (General Discussion)
by drt 6/13/2023 1:53:22 AM(UTC)
Smooth Merge for Multiview (General Discussion)
by drt 6/12/2023 11:31:38 PM(UTC)
Merge Transition from Input to Mini Mix (Feature Requests)
by eterelle 2/6/2023 5:44:20 AM(UTC)
Merge / Flatten option of Multiview (Feature Requests)
by MaxSpecs 11/30/2022 7:05:34 AM(UTC)
Fun with Merge (3rd Party Software and Development)
by j_dublay 11/29/2022 1:44:16 PM(UTC)
Merge/Input Trigger Errors causing me stress (General Discussion)
by edscanada 5/18/2022 2:15:01 AM(UTC)
Workaround merge transition for PIP overlays (General Discussion)
by JW 12/10/2021 5:53:32 AM(UTC)
Merge Transition Cuts off Borders (Feature Requests)
by MarkNF82 8/18/2021 11:48:00 PM(UTC)
Merge background (General Discussion)
by Joeboe 6/22/2021 10:15:14 AM(UTC)
merge transition problem with 1st input box (General Discussion)
by bidyut 6/21/2021 9:23:03 PM(UTC)
Animation Border in Merge Transition (Feature Requests)
by Roi 5/18/2021 9:42:09 PM(UTC)
What does the 'Merge' transition do when used for a Stinger? (General Discussion)
by SeanEmer 5/7/2021 3:04:04 PM(UTC)
Border with Merge Animation (Input/Layer) (PLEASE FIX THIS) (Feature Requests)
by Johncris256 4/17/2021 1:23:30 AM(UTC)
More control of Merge layer reordering. (Feature Requests)
by RichDanby 12/3/2020 10:05:00 PM(UTC)
Background for Merge Transition (General Discussion)
by tvfabrik 10/29/2020 5:23:41 AM(UTC)
COVID emergency solution - Commentators for a Football Game (vMix Call)
by tgdzapa1 9/4/2020 9:09:24 PM(UTC)
How to stop GT titles from animating after merge transition (GT)
by Plamen 7/13/2020 10:44:10 AM(UTC)
Merge transparent problem (Feature Requests)
by mmjoy 5/7/2020 2:26:11 AM(UTC)
emergency (General Discussion)
by STADIORADIO 12/14/2019 11:45:14 PM(UTC)
Merge Bug or Feature (General Discussion)
by JohnnyFlash 11/6/2019 10:35:19 AM(UTC)
