Bandit62
#1 Posted : Sunday, December 25, 2016 1:09:26 AM(UTC)
Rank: Guest
Groups: Guests
I have just acquired an AJA Kona 3 capture card...I do not see that card listed in supported hardware, I see the newer Knoa3G, and am wondering if the support will work for the older Kona3 card....I have not yet received the card, but it is being sent to me, so that is why I am asking before it arrives...
Ed Tech
#2 Posted : Sunday, December 25, 2016 5:50:59 AM(UTC)
Ed Tech
I am so sorry to tell you that the Kona 3 is not supported. I believe it has something to do with the SDK.
Bandit62
#3 Posted : Sunday, December 25, 2016 4:12:16 PM(UTC)
Rank: Guest
Groups: Guests
Then, will the Blackmagic Design Desklink Duo work.....I have one of them promised to me, just waiting til the holidays are over to collect it
Maximus
#4 Posted : Monday, December 26, 2016 10:50:59 AM(UTC)
Maximus
Both the Decklink Duo and Duo 2 will work.
Peter B
#5 Posted : Monday, December 26, 2016 4:20:16 PM(UTC)
Peter B
That's the nice thing about Decklink, any old card just works but I hold my breath
when it goes for a firmware update. I've bought a few used with no problems so far.
Pity about the Kona 3, we recently had to ditch two as it wouldn't talk to Premier updates.
Similar Topics
AJA KONA 3G (Hardware Compatibility)
by Dimasik005 3/17/2024 3:56:26 AM(UTC)
AJA Kona 3G Audio Breakout Box (Hardware Compatibility)
by Bruce Hamady 12/24/2020 9:44:05 AM(UTC)
KONA 3G disables GPU (Hardware Compatibility)
by KevSoleil 4/30/2020 3:27:47 AM(UTC)
AJA KONA 3G Video Capture Card (Hardware Compatibility)
Belarus Joeboe 1/9/2019 11:47:45 AM(UTC)
AJA Kona 3 Capture Card (General Discussion)
by Princepee 2/17/2017 2:26:40 PM(UTC)
AJA Kona 3g and Motherboard Question (Hardware Compatibility)
Belarus LAJDigital 9/18/2015 10:08:40 AM(UTC)
Aja Kona 3 (not 3G) (Hardware Compatibility)
by vitorio123 7/26/2015 5:47:51 AM(UTC)
2-AJA Kona 3G cards in Magma Expressbox 3T Expansion (Hardware Compatibility)
by epicenter800 7/5/2015 10:41:13 AM(UTC)
Does Kona 3G/QUAD support 4xHD-SDI inputs and HDMI+Analog outputs simultneously with vMix 14? (Hardware Compatibility)
by Ernest Król 10/4/2014 7:31:55 AM(UTC)
