 Joined: 12/24/2020(UTC) Posts: 2  Location: California
                Is anyone using the Kona 3g breakout box with VMix? Video works and I do get audio out embedded in SDI but I can't get audio out on the RCA monitor jacks or the aes/ebu breakouts. I know the breakout works because the green led is on and I can output audio with Premiere and AJA Control Room. I've selected the Kona ASIO output for my master or headphones) with no luck. If someone is having success, can you tell me your settings?
