Rank:: Newbie
Do you Vmix can work with Aja Kona 3 (not 3G)? I have seen in the hardware compatibility that is not supported, but the drivers are the same as for 3G and 4K https://www.aja.com/en/support/legacy/kona-3A simple yes or no? Sorry to google translate English; (
Joined: 7/9/2014(UTC) Posts: 9 Location: Grass Valley, CA
No, the Kona 3 will not work with vMIx. It uses an older driver set that is not supported.
-EricN AJA Video
 1 user thanked ericn for this useful post.
