vitorio123
#1 Posted : Sunday, July 26, 2015 5:47:51 AM(UTC)
vitorio123
Do you Vmix can work with Aja Kona 3 (not 3G)?
I have seen in the hardware compatibility that is not supported, but the drivers are the same as for 3G and 4K
https://www.aja.com/en/support/legacy/kona-3
A simple yes or no?
Sorry to google translate English; (
ericn
#2 Posted : Tuesday, July 28, 2015 1:28:41 PM(UTC)
ericn
No, the Kona 3 will not work with vMIx. It uses an older driver set that is not supported.
-EricN
AJA Video
thanks 1 user thanked ericn for this useful post.
sinc747 on 7/28/2015(UTC)
