Rank: Guest
Groups: Guests
I have just acquired an AJA Kona 3 capture card...I do not see that card listed in supported hardware, I see the newer Knoa3G, and am wondering if the support will work for the older Kona3 card....I have not yet received the card, but it is being sent to me, so that is why I am asking before it arrives...
Joined: 10/29/2013(UTC) Posts: 57 Location: Conroe TX
Thanks: 6 times Was thanked: 5 time(s) in 5 post(s)
I am so sorry to tell you that the Kona 3 is not supported. I believe it has something to do with the SDK.
Rank: Guest
Groups: Guests
Then, will the Blackmagic Design Desklink Duo work.....I have one of them promised to me, just waiting til the holidays are over to collect it
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
Both the Decklink Duo and Duo 2 will work.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
That's the nice thing about Decklink, any old card just works but I hold my breath when it goes for a firmware update. I've bought a few used with no problems so far.
Pity about the Kona 3, we recently had to ditch two as it wouldn't talk to Premier updates.
