curtismacd31
#1 Posted : Wednesday, December 21, 2016 2:35:50 PM(UTC)
curtismacd31
Hi All,
I have a question, I am looking at using an AJA IO 4k, but does anyone know, Can I use 4 SDI Inputs and have a simultaneous external SDI output for program? or am I limited to 3 inputs if I want to use an output as well?
Thanks for your help on this.
ask
#2 Posted : Wednesday, December 21, 2016 5:08:53 PM(UTC)
ask
curtismacd31
#3 Posted : Wednesday, December 21, 2016 6:04:32 PM(UTC)
curtismacd31
ask wrote:
https://www.aja.com/assets/support/files/3799/en/IoXT_4K_Manual_v12.5.pdf
That is not very helpful, it does not say for sure.
#4 Posted : Wednesday, December 21, 2016 7:57:36 PM(UTC)
@ curtismacd31
My guess is that it is either Input OR Output but not simultaneous IN and OUT on the same connector.
I could be wrong but this is what my understanding is from page 13 of the above pdf manual:
"Bi-directional SDI I/O Four bidirectional BNC connectors can be configured via the AJA Control Panel for: • HD/SD inputs (x2) and outputs (x2) • Or you can input or output 4 channels of video representing individual quadrants of the higher definition Ultra HD (3840x2160) and 4K (4096x2160) formats."
#5 Posted : Wednesday, December 21, 2016 8:53:10 PM(UTC)
The IO4K is a four channel device, so you can do 4 things at once, that could be 3 in + 1 out or 4 in only or 2 in + 2 out
Kelvin
#6 Posted : Wednesday, December 21, 2016 10:42:13 PM(UTC)
Kelvin
The AJA has 2 thunderbolt ports. You could try to daisy chain a BM Mini Monitor to get the extra channel. I don't have an AJA, but I have done this successfully with another thunderbolt enclosure and my new TB3 laptop, but didn't work with my older TB1 laptop.
h2video.nl
#7 Posted : Thursday, December 29, 2016 2:52:28 AM(UTC)
h2video.nl
Also have a look at the discussion about using the Akitio thunder3 pcie enclosure. this can hold a bm duo 2 card or even a decklink quad 2 with eight inputs outputs. the advantage is that it is more flexible and cost effective. the enclosure is about 300 and cards you may already have...
it runs on thunderbolt 3 so it is also future proof.
currently testing this and very happy. I can also daisy chain a second set or a bm mini ...
stefan
curtismacd31
#8 Posted : Thursday, December 29, 2016 5:18:29 PM(UTC)
curtismacd31
stefan
I do have an Akitio thunder2 with a Startech Thunderbolt3 to Thunderbolt2 adapter. I used it with a Decklink Quad 2 that I borrowed to test and it worked great. I just came across a AJA io 4K for $1000USD and was hoping it would do 4 In and 1 Out simultaneously, but it won't. Still a great price for that unit. I'm either gonna sell it and get a BMD Decklink Quad2 or maybe keep it and use it with a BMD Mini Monitor.
Thanks everyone for the replies.
Similar Topics
AJA Io 4k Plus - what ports that vMix can use? (General Discussion)
by Paul CVP 11/6/2024 9:50:28 AM(UTC)
Bootcamp, iMac and AJA io 4K...not working (Instant Replay)
by lyco 2/13/2022 12:45:38 AM(UTC)
Aja Io 4k Plus Audio Output question (Hardware Compatibility)
by Burnmaester 1/21/2021 5:16:57 AM(UTC)
Output with AJA io 4k plus (Hardware Compatibility)
by VJB 9/28/2020 12:03:13 AM(UTC)
Two AJA IO 4K+ Questions (General Discussion)
by allklier 6/3/2020 10:11:37 AM(UTC)
Alienware 17 R3 with AJA io 4K (Hardware Compatibility)
by voyagermix 5/20/2019 1:56:41 AM(UTC)
AJA IO 4K Plus HDMI Out (Hardware Compatibility)
by chrisdurkee 11/2/2018 11:11:21 AM(UTC)
AJA Io 4k and 4k Plus together 8 Inputs ? (General Discussion)
by BigApple 10/15/2018 3:56:08 PM(UTC)
aja io 4K plus (Hardware Compatibility)
by radamo 1/13/2018 8:34:18 AM(UTC)
AJA IO 4K thoughts and observations... Can you confirm? (Hardware Compatibility)
by ben1000 10/7/2017 8:41:54 PM(UTC)
Aja IO 4K tearing lines in vmix input (General Discussion)
by BigApple 8/12/2017 9:07:13 PM(UTC)
Aja IO 4K green image (General Discussion)
by BigApple 8/10/2017 11:06:09 AM(UTC)
Setting Up AJA IO 4K for 4 SDI inputs? (Hardware Compatibility)
by rjmurdock 3/4/2017 10:42:52 PM(UTC)
Aja io 4k with thunderbolt 1 (General Discussion)
by GeorgeBailey 9/8/2015 5:32:57 AM(UTC)
Mini-DP vs Thunderbolt for AJA Io 4K (General Discussion)
by Adriankey4 4/29/2015 9:53:42 AM(UTC)
New AJA io 4k (Hardware Compatibility)
by illpicasso 2/11/2014 3:09:45 PM(UTC)
