Please forgive if this has been posted already but I could not find any.
I use the latest 19.0.0.54 trial version and the latest driver from AJA v13 but somehow my UHD image (2160/30) from my camera is somehow green Like a color space is wrong... but anything I try I never get it to work normal. I can see the feed but all is green ... when I use the aja software to view the image it is normal but in vmix it is green
Any advice would be really helpful Thank you in advance
What camera are you using?
In vMix, what are your Frame Rate, Resolution, and Input settings for the camera?
SportsNetUSA.net wrote:What camera are you using?
In vMix, what are your Frame Rate, Resolution, and Input settings for the camera? Panasonic GH5 HDMI out UHD/29.97 HDMI All default settings. On the AJA software it is fine but once opened in Vmix it is tinted green
