lyco
#1 Posted : Sunday, February 13, 2022 12:45:38 AM(UTC)
lyco
Senegal
Hello VMIXers,
Could you please help me on this...
I've installed Windows10 on my iMAC 14,3 (i5-8GB RAM- 1Tb) using bootcamp. The goal is to use vmix with my AJA IO 4k capture card.
The problem is that my capture card is not recognized by the system when I plugged my thuderbolt2 cable.
Is the issue with the thunderbolt2 driver?
Radiotvpat1982
#2 Posted : Monday, February 14, 2022 12:50:19 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
If you intend to use VMIX replay it is so specific to the suggested Hardware that VMIX recommends.
I would highly suggest not trying to use a MAC to do Replay. Depending on the number of inputs it takes the right combo of CPU, high speed storage, and data transfer. Just not sure you will get the results you are looking for.
Here are the suggested Hardware for up to 4 inputs:
https://www.vmix.com/pro...erence-systems.aspx#ruby
and up to 8 inputs:
https://www.vmix.com/pro...nce-systems.aspx#diamond
lyco
#3 Posted : Monday, February 14, 2022 5:23:08 AM(UTC)
lyco
Senegal
Thanks for the reply.
My bad, I posted my question in the bad section. I want to use the iMAC/Bootcamp + Vmix as a video switcher. I read in this forum that is quite possible and would run smoothly..
