Maximus
#1 Posted : Tuesday, June 21, 2016 9:56:07 PM(UTC)
Maximus
I am using Behringer PL-1 and DV-1 for Replay. My objective is to access most of the replay features via these Controllers and so far it is working out great. They are however a few shortcuts that are not available currently that would help considerably in my workflow. Here is a list of Shortcuts and Changes I would love to see implemented.
1. SelectLastEvent. A SelectFirstEvent would be great too.
2. ReplayCopySelectedEvent. Currently there is only a ReplayMoveSelectedEvent
3. Leave the Last Played Event Selected. Currently after an event has Played, on completion of the Replay, no event is highlighted.
4. When no event is Highlighted, ReplaySelectPreviousEvent goes to the first Event in the List. It would probably be netter if the Last Event was selected instead. If no event is selected, ReplaySelectNextEvent does nothing.
5. The PL-1 has a Fader Control that is not detected by the 'Find Contol'. I believe it transmits Pitch Bend Control Data. Can this be mapped to ReplaySetSpeed?
6. Some Rotary Encoders use +Value or -Value to Increment/Decrement. Others use += or -= to Increment or Decrement. e.g. SetVolume uses +=/-= while ReplayMoveSelectedIn/OutPoints uses -/+ only. This I found out by trial and error, but it would be great if it was consistently one or the other. I do not recall seeing anything in the help about this, but if it can't be changed, then it should be clear which control uses what syntax.
7. SetRateSlowMotion appears under 'All' Tab, but it does not appear in the 'Replay' Tab
8. Is it possible for vMix to send Midi Data to utilise the Position Markers for the Encoders in the Behringer Devices. Also it would be great if the VU Meter on the MM-1 can be mimic the vMix Master Audio Meters.
In addition to the Pl-1 and DV-1, I also have the DC-1 and MM1 and these are what I am configuring and testing as my dedicated hardware Controller for vMix. It is relatively inexpensive, totally customisable and provide the tactile feedback I prefer in a controller. If you get around to implementing these suggestions and you would like for me to beta test, I would be happy to.
Maxi
YoHo and a Bottle of Rum
Similar Topics
Thank for new vMix Replay Shortcuts v29 (Beta Discussion)
by InstantReplayGO 8/17/2025 12:02:44 PM(UTC)
Add new vMix Replay shortcuts (Feature Requests)
by InstantReplayGO 4/26/2025 3:12:21 AM(UTC)
New vMix Replay Shortcuts (Feature Requests)
by WesleyFernandes 11/3/2022 11:57:25 PM(UTC)
v26 New vMix Replay shortcuts (General Discussion)
by WesleyFernandes 10/26/2022 7:59:14 AM(UTC)
vMix 24 Instant Replay shortcuts (Feature Requests)
by MarkNF82 2/7/2021 4:42:08 AM(UTC)
Some Replay shortcuts not working (Instant Replay)
by MikeBenke 10/17/2018 12:35:10 AM(UTC)
Instant Replay shortcuts issues and questions (Instant Replay)
by Rinsky 3/1/2018 3:48:47 PM(UTC)
vMix Midi Replay Shortcuts (General Discussion)
by nc 2/1/2018 6:19:41 AM(UTC)
Replay Shortcuts (Instant Replay)
by Jorge Costa 5/22/2017 9:43:31 PM(UTC)
Additional Instant Replay Shortcuts (Feature Requests)
by DeeJay 10/2/2015 2:29:17 PM(UTC)
