mikekay
#1 Posted : Monday, March 21, 2016 3:45:21 PM(UTC)
mikekay
What use are virtual inputs? What would you use them for? I know how to set them up, just don't understand why they would be useful.
Any responses most appreciated.
ask
#2 Posted : Monday, March 21, 2016 4:54:53 PM(UTC)
ask
A good use other is to setup a shot with lower thirds or other overlays as well as the "clean" original shot. Really, it's all about trying out ideas and experimenting.
kgoodyer
#3 Posted : Tuesday, March 22, 2016 1:17:21 AM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Virtual Inputs have proved to be a VERY useful, and time saving feature. I have 96 VT's, each VT has a series of triggers, positions, and transforms. Instead of having to set up every VT input separately, I created on VT input, set it all up with the correct triggers, positions and transforms. I then created 95 copies of it using Virtual Inputs, and then just went through each one, changing the input file to the correct file. I did not have to sett loads of triggers, positions and transforms to each individual input, and thus probably saved my self many hours of work.
I have also found them very useful when setting up multi view inputs, where I have had several 'similar' requirements - maybe just one element being different, but I can create a whole second virtual input, and then just change the single element in that composition, without having to set up the whole multi-view layout a seconds time.
All The Best
Keith
#4 Posted : Tuesday, March 22, 2016 9:02:23 AM(UTC)
@ mikekay
A classic example for us cannucks, would be a single shot of the hockey scoreboard that you could make 7 Virtual copies of and then crop, size and place the various elements into some custom scoreboard overlays (Time/Home score/Away score/home penalty 1/home penalty 2/away penalty 1/away penalty 2).
r@wisla uses this concept for his basketball games for the game and shot clocks as seen here:
( http://forums.vmix.com/d....aspx?g=posts&t=2058 )
Another use might be for a reflection in a Virtual Set if your set doesn't have an appropriate UV map in place for that.
The uses are really only limited by your need, imagination and creativity.
Hope that answers your question some.
mjgraves
#5 Posted : Tuesday, March 22, 2016 11:29:34 AM(UTC)
mjgraves
I see virtual inputs as a way to combine "master elements" in varying ways, without requiring each to be a separate instance of the item.
Example #1 - Sponsor logo
For example, let's imagine a sponsor logo. It's one shot in the project. Then I use a handful of virtual inputs to offer that logo re-positioned in various ways around the frame.
When the sponsor changes I change the master shot, replacing the old logo with a new one. All places where that logo appeared are updated automatically. That's a tremendous time saver.
Example #2 - Animated background (MP4)
Similarly, I have an animated background that I use a lot. It's loaded to one shot on it's own. There after it appears as a layer in many virtual shots. If I change the master background all instances of it in the various virtual shots change.
Similar Topics
What is "virtual inputs"? (General Discussion)
by TL68 3/6/2026 12:46:15 AM(UTC)
Feature request: Video delay for virtual inputs (Feature Requests)
by semenov_nick_1990 2/12/2026 6:45:18 PM(UTC)
Merge between source and its virtual input when flatten layered (Feature Requests)
by semenov_nick_1990 6/19/2025 7:40:49 PM(UTC)
Issue with Source Dropped and Virtual Input (General Discussion)
by afonia 5/27/2025 12:49:17 AM(UTC)
Create Input at his Postion" vs "Create Virtual Input (General Discussion)
by hparsons 12/17/2024 4:33:07 AM(UTC)
Virtual Input - Camera hotspots (General Discussion)
by WaseemAhmad 9/13/2024 5:13:22 AM(UTC)
Virtual inputs of a SRT input with different audios each (Feature Requests)
by ccriddle 8/29/2024 8:05:27 AM(UTC)
Script to determine "parent" of virtual input, then update virtual input? (General Discussion)
by FoolOnTheHill 2/14/2024 7:59:28 AM(UTC)
vMix PTZ Virtual Inputs (General Discussion)
by M.T. 1/17/2023 12:25:32 PM(UTC)
PTZ virtual input problem (General Discussion)
by ForbJM 1/11/2023 12:37:26 AM(UTC)
Create Virtual Input from Input Creation Menu (Feature Requests)
by ChrisG_NRN 12/15/2022 1:38:31 AM(UTC)
Show input name as well as number in virtual input list (Feature Requests)
by cmcloughlin 10/5/2022 11:02:29 PM(UTC)
Virtual Inputs should not break the transitive passing of Tally information (Feature Requests)
by engelschall 6/26/2022 10:10:24 AM(UTC)
Identify virtual input parent in API (Feature Requests)
by Mollertom 11/30/2021 2:32:43 AM(UTC)
Preview and Program indication for Virtual inputs and PTZ positions (Feature Requests)
by FarmhouseMusic 10/31/2021 3:24:29 PM(UTC)
Add desired input number to new virtual inputs (PTZ presets) (Feature Requests)
by JW 7/4/2021 4:21:58 AM(UTC)
Shortcut to Move New Virtual Input to a preconfig. Category (Feature Requests)
by damean 6/26/2021 5:39:20 AM(UTC)
Alternate aspect ratio of camera not saving on virtual input (General Discussion)
by GraceTemTech 6/11/2021 3:01:26 PM(UTC)
ptz - virtual input - fade in live video or preview? (Feature Requests)
by Martinius 5/7/2021 7:43:11 PM(UTC)
Update PTZ Virtual Input by Index Number? (General Discussion)
by BairStrokes 4/9/2021 11:10:16 PM(UTC)
PTZ Virtual Input thumbnail (General Discussion)
by denimassi 3/29/2021 10:10:58 PM(UTC)
Update PTZ Virtual Input by Index Number (General Discussion)
by lbrentevans 3/28/2021 9:25:16 AM(UTC)
Avoid selecting "wrong" PTZ virtual input (General Discussion)
by Bob Brazner 1/22/2021 10:34:11 AM(UTC)
PTZ virtual inputs in Virtual Set (General Discussion)
by alexpearce 12/13/2020 10:46:51 PM(UTC)
Multiple Instances of NewTek NDI Webcam Input (Virtual Input) (NDI)
by lestra 12/10/2020 11:06:07 PM(UTC)
My virtual input is displayed black in the "input picker" (General Discussion)
by bkemperman 12/9/2020 10:56:35 PM(UTC)
Preposition PTZ to virtual input preset before transitioning video (General Discussion)
by m_elias 12/7/2020 5:06:50 AM(UTC)
Virtual Input Camera Speed shortcut (General Discussion)
by cyeo 11/13/2020 4:38:57 PM(UTC)
MS Teams Virtual Input no audio in meeting solved (NDI)
by Pepsi(~) 11/13/2020 7:11:22 AM(UTC)
PTZ Preset Views / Virtual Input management (Feature Requests)
by rtstreamer 10/19/2020 2:34:50 AM(UTC)
