4 Pages<1234>
NDI
sinc747
#41 Posted : Saturday, January 30, 2016 4:57:58 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
vmixsupport wrote:
The right-click feature is just a way to save some screen real estate for all of your NDI sources. Each NDI source can be added like any other input. So if you have 4 NDI inputs you could have 4 windows for them. Then you just select them as you would a normal input and transition between them.
So, the CPU/GPU impact on the PC would be the same using NDI camera resources as using local camera resources*?
- Tom
* - cameras physically connected to the PC running vMix 17 through a capture card or other physical device.
watchfulone
#42 Posted : Tuesday, February 2, 2016 12:24:41 AM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
admin wrote:
Some answers to some common questions below:
Is it GPU or CPU based?
NDI encoding/decoding is CPU based using around 5% per 1080p30 camera on a modern i7 CPU.
What color spaces are supported?
Frames are sent/received from NDI at 4:2:2 8 bit, but NDI compresses at 16 bit internally.
NDI also has full support for alpha, sent as a separate channel. (so 4:2:2:4)
Will there be converter boxes?
More than likely, possibly from more than one manufacturer.
We are working on our own prototypes using off the shelf SFF (small form factor) PCs, but
the codec can theoretically be used on devices as small as a standard HDMI to SDI mini converter.
The main advantage of one of these converters is you will no longer need a capture card
opening up most laptops to multi camera productions without the need for thunderbolt!
My hope is the converters will be affordable.
What is the stream bitrate?
To my knowledge it is variable bit rate.
I've seen around 50Mbps to 100Mbps per camera in my tests so far.
Will there be iOS and Android support?
Support for these devices, specifically the ARM processor is being worked on at NewTek.
Not sure if they will release software for these devices, but then NDI is open so if you are a developer
sign up for the SDK and start building your own!
Will Desktop Capture use NDI?
Yes, we plan to completely replace vMix Desktop Capture to use NDI.
NewTek will also release an app that does much the same thing.
What vMix licenses will we need?
One vMix license per PC that is running vMix at the same time.
If you use a 3rd party NDI app on a second PC or vMix Desktop Capture, you won't need the second license.
Do I need two copies of vMix to use capture cards from multiple PCs?
No. One of the cool things NewTek is working on is a universal PC app that can convert
any capture cards in the PC it is running from into NDI.
So you could have a vMix laptop in your studio and a rackmount PC with all the capture gear
locked away!
Excellent work Martin, I can hardly wait this is going to be revolutionary.
thanks 2 users thanked watchfulone for this useful post.
PFBM on 2/13/2016(UTC), vijay6672 on 2/26/2016(UTC)
epicenter800
#43 Posted : Saturday, February 13, 2016 1:29:10 PM(UTC)
epicenter800
Any idea if NDI will support 10 gigabit networks?
thanks 1 user thanked epicenter800 for this useful post.
PFBM
#44 Posted : Saturday, February 13, 2016 2:19:19 PM(UTC)
PFBM
it does not matter....
it´s all networks 100, 1000, 10k.... the more band you have , the more NDI streams you can have at the same time....
Cheers,
PFBM
Innomedia
#45 Posted : Sunday, February 14, 2016 1:56:21 PM(UTC)
Innomedia
Was thanked: 19 time(s) in 10 post(s)
Hi
We are back from our trip to ISE in Amsterdam and we did a little research regarding NDI. First of all we visited NEWTEK and they gave us a little insight of this new (and to my personal view groundbreaking) technology. We all here as vMix users can be very happy that Martin has implemented NDI to new vMix17. The demo at NEWTEK booth was very impressive, they showed interaction between different tricaster products on NDI basis. You can use all inputs and outputs within the same network no matter where the source is plugged in. And they showed in a split-screen that latency is very very low (you can hardly see any difference). Of course they only had to bridge a few metres in their booth but they promised that the latency behaviour does not change even when using longer distances in a network. Sounds very promising.
Unfortunately we were not able to find any hardware stuff like converters (HDMI / SDI to NDI) but this is not a big surprise. The NDI standard was launched in the end of 2015 and of course it takes some time to develop appropriate hardware. Maybe at NAB we will see some devices.
All capture card manufacturers we visited (Matrox, Blackmagic, Datapath, Yuan, AJA) are familiar with NDI and most of them told us that the engineers are working on integration of NDI standard. Only at Magewell booth they did not know what we were talking about but they promised to push their engineers, too. I believe that the engineers already know, the girls at the trade shows are just responsible for sales and not for technical questions.
NEWTEK also told us that most camera manufacturers (Canon, Sony, Panasonic) are in close contact with them to integrate NDI directly to their products.
As a summary we can say that NDI is on its way to the market. It will take a while until we have supporting products and devices but once they are available I believe it can change the market. Just my personal view (and hope).
Regards
Karsten
thanks 7 users thanked Innomedia for this useful post.
richardgatarski on 2/14/2016(UTC), Squier on 2/14/2016(UTC), sinc747 on 2/14/2016(UTC), watchfulone on 2/15/2016(UTC), DYosua on 2/15/2016(UTC), mjgraves on 2/17/2016(UTC), ClementN on 3/22/2016(UTC)
richardgatarski
#46 Posted : Sunday, February 14, 2016 3:32:18 PM(UTC)
richardgatarski
Thank you Karsten for the update, and that you express the interest from us vMix users to Newtek and important h/w manufacturers.
epicenter800
#47 Posted : Tuesday, February 23, 2016 4:36:57 PM(UTC)
epicenter800
A few more NDI questions...
Any idea on how much CPU usage desktop capture via NDI will take? I typically ingest 4 laptops for corporate meetings via HDMI capture?
Will we be able to iso record any NDI inputs via Multicorder?
Will NDI processing happen only on the cpu or are there plans for GPU processing?
Thanks!
ask
#48 Posted : Tuesday, February 23, 2016 4:57:31 PM(UTC)
ask
NDI is a Newtek product so some of your questions should be directed to them. However, % CPU use will depend on your system. In my testing it has been as little as 1-2% and up to 10% depending on the NDI source and the system you are ingesting it on. In terms of vMix, as Martin has explained a number of times the NDI source is treated as any other input source so vMix will use both GPU and CPU as normal.
PFBM on 2/24/2016(UTC)
r@wisla
#49 Posted : Thursday, February 25, 2016 6:05:40 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
It's recommended / requiered to have 1gbps Local Area Network to use multiple NDI sources.
Maybe it was on Tom's Streaming Idiots show or somewhere else, that you need to add a 1gbps switch to your network, connect all the devices You want and you got it.
My question is: switch or router?
It's obvious that it's necessary to have a router in our LAN. BUT, does it need to be a 1gbps one? Or could it be (our old) 100 mbps router connected to 1gbps switch, then all of the devices connected to the switch and the speed will be the same as with 1 gbps router only? (or 1 gbps router + 1 gbps switcher)?
ask
#50 Posted : Thursday, February 25, 2016 7:00:41 AM(UTC)
ask
The answer is switch. They ensure that each port is allocated a full 1 gig rather than sharing the bandwidth across all ports which is what the older devices did. Also you want a full duplex switch. The good news is that in most routers, these full duplex switches are built in. So if you only need 4 ports, your ADSL/Cable/Fibre modem/Router should be fine.
Kelvin
#51 Posted : Thursday, February 25, 2016 4:59:52 PM(UTC)
Kelvin
Any chance someone could make an HDMI - NDI converter out of a Rasberry Pi or something similar?
Lennart
#52 Posted : Tuesday, March 1, 2016 4:30:45 PM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
I don't think you'll see a HDMI to NDI converter based on Raspberry Pi, but a NDI to HDMI is not unthinkable. The problem is that the Raspberry Pi doesn't have any video capture capabilities.
stevespaw
#53 Posted : Tuesday, March 1, 2016 8:16:34 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Lennart wrote:
The problem is that the Raspberry Pi doesn't have any video capture capabilities..
Really ??? :-)
http://www.auvidea.eu/index.php/theme-styles/2014-12-30-22-32-06/b100-hdmi-to-csi-2-bridge
Steve
madness
#54 Posted : Wednesday, March 2, 2016 10:52:32 AM(UTC)
madness
stevespaw wrote:
Really ??? :-)
Steve
Do you know of something like this but for VGA capture on the Pi?
r@wisla
#55 Posted : Tuesday, March 22, 2016 12:48:21 PM(UTC)
r@wisla
So, now everyone has oportunity to touch the NDI :)
newtek.com/ndi
#56 Posted : Tuesday, March 22, 2016 10:55:07 PM(UTC)
Was thanked: 4790 time(s) in 1644 post(s)
vMix 17 Beta released with all the info below:
http://forums.vmix.com/d....aspx?g=posts&t=5955
madness on 3/23/2016(UTC)
PFBM
#57 Posted : Tuesday, August 23, 2016 5:12:27 PM(UTC)
PFBM
Update
B101 HDMI to CSI-2 bridge for Raspberry Pi
http://www.auvidea.eu/do...2015-12/news_2015-12.pdf
AElli
#58 Posted : Wednesday, August 24, 2016 5:16:09 PM(UTC)
AElli
BFPM
If this is what it appears to be, this will change the pace of upcoming HDMI - NDI converters.
I have a post on the Newtek forum asking if NDI code is available for arm devices, I was thinking of NDI into a pi or odroid and HDMI out, but with this card it looks like it can operate in the opposite direction as well. HDMI in NDI network out. Just don't know if Newtek have a version for arm.
A.
AElli
#59 Posted : Wednesday, August 24, 2016 5:25:24 PM(UTC)
AElli
AElli wrote:
BFPM
A.
Ah just read up more on this, its not what I thought it was.. Thought it was a HDMI input card to replace the pi camera input.. Looks like this card is a HDMI to HDMI bridge.. HDMI into the card passes its video to the HDMI output of another pi on the same network.. Whilst still an interesting idea, really little more at this time than a HDMI over cat5 adapter..
A.
diegopvp
#60 Posted : Friday, September 30, 2016 9:31:32 AM(UTC)
diegopvp
Hi, there are some USB adapters for PC laptops or desktops that can handle HDMI or SDI inputs up to 1080p and can be used as a source for VLC Player. Then you can install Newtek NDI Tools (free download) in the same computer and using the free Newtek NDI VLC plugin you can display the HDMI or SDI input signal and make it available as NDI source for VMix or any other NDI capable switcher application. In the USA you can get the USB adapters from here: https://store.techexport...ollections/e-mediavision . Feel free to ask if anyone need further information. Thanks.
Similar Topics
vMix 29.0.0.49 NDI Input locking up (General Discussion)
by Roy Sinclair 10/19/2026 12:04:49 AM(UTC)
vMix video/audio stuttering via NDI from Dinesat 12 Visual (NDI)
by Gabriel502 9/11/2026 5:43:57 AM(UTC)
NDI input is black (NDI)
by Abayomitsn 8/23/2026 11:07:03 PM(UTC)
New vMix build 5 NDI 2 SDI streaming (Systems)
by alefello 8/18/2026 12:10:10 AM(UTC)
NDI and Video inputs blanking out. (General Discussion)
by boris9831 7/14/2026 7:37:23 AM(UTC)
NDI and OMT on vMix both running (OMT - Open Media Transport)
by Wouter 7/10/2026 12:44:33 AM(UTC)
Ability to set specific NDI port for Outputs (Feature Requests)
by jet 6/24/2026 7:39:23 PM(UTC)
Hardware Converter: SDI to NDI and DANTE Ethernet Card (Hardware Compatibility)
by blopes 6/10/2026 7:40:05 AM(UTC)
Excessive Source Drops, Render Drops, and Sync Issues with PTZOptics Studio 4K via NDI in vMix 29 (NDI)
by Matts887 6/2/2026 10:38:07 AM(UTC)
Powerpoint converter NDI/OMT (3rd Party Software and Development)
by mavik 5/22/2026 12:24:30 AM(UTC)
vMix Sees NDI Cameras, But Black Screen Using Them For Replay? (NDI)
by JohnDoe415 5/15/2026 8:59:28 PM(UTC)
Manufacturer claims OMT image quality is poorer than NDI? (OMT - Open Media Transport)
by jet 5/9/2026 3:27:36 PM(UTC)
Individual SRT Status (Feature Requests)
by alias 5/6/2026 2:18:12 AM(UTC)
how to force NDI HX3 capture (NDI)
by h2video.nl 4/8/2026 4:13:39 AM(UTC)
NDI hangs up (NDI)
by brianconverse 4/1/2026 6:45:00 AM(UTC)
Zoom Caller NDI OUT (Feature Requests)
by JDroadie 3/28/2026 1:04:52 AM(UTC)
Ptz NDI with vmix leggings (General Discussion)
by Almeida 3/26/2026 7:32:19 AM(UTC)
NDI routing on specific NIC (NDI)
by florinvg 3/8/2026 3:39:07 AM(UTC)
AUDIO mute toggle - what is the Event to indicate it is muted for an activator (General Discussion)
by Curtis Martin 2/28/2026 6:08:44 AM(UTC)
HDMI to NDI (NDI)
by MickeyMJJ 2/23/2026 7:31:02 PM(UTC)
Remote Control for BirdDog Play & NDI Studio Monitor (iOS & Android) (NDI)
by youcci 2/18/2026 8:32:04 PM(UTC)
Play Outro Video When Ending Live Stream (General Discussion)
by bholland 2/16/2026 4:13:12 AM(UTC)
Source NDI view (Feature Requests)
by Srivelles 2/11/2026 6:13:15 PM(UTC)
fullscreen output NDI (Feature Requests)
by christianb 2/7/2026 8:21:10 AM(UTC)
NDI HX support for Output (Feature Requests)
by inquattro 2/4/2026 7:20:28 AM(UTC)
More External Destination please from 4 to 6 also with OMT and NDI (Feature Requests)
by inquattro 2/4/2026 7:17:57 AM(UTC)
Birddog XL Ultra Full NDI Crashes vMix (NDI)
by VVEPBrian 1/27/2026 9:48:11 AM(UTC)
Pulling Multiple Screen Shares as NDI Feeds (NDI)
by knbPixels 1/23/2026 4:37:16 AM(UTC)
NDI 6.x Discovery support (Feature Requests)
by fgolman 1/22/2026 2:56:09 PM(UTC)
NDI Audio Capture only (NDI)
by waxxel 1/14/2026 6:16:25 AM(UTC)
4 Pages<1234>
