4 Pages123>»
NDI
PFBM
#1 Posted : Thursday, January 21, 2016 3:48:57 PM(UTC)
PFBM
Hi !
a few things i would like to know about NDI :
- is it GPU or CPU processing based ?
- how much CPU per feed , in full hd ?
- will there be a ndi virtual capture I/O device on Windows and OSX ?
- is it 422 10 bit or 8 bit ?
Cheers,
PFBM
Kelvin
#2 Posted : Thursday, January 21, 2016 4:18:18 PM(UTC)
Kelvin
Also, will there be HDMI->NDI converter boxes similar to the HDMI->SDI converter boxes that exists today?
thanks 1 user thanked Kelvin for this useful post.
PFBM on 1/21/2016(UTC)
mjgraves
#3 Posted : Thursday, January 21, 2016 4:21:13 PM(UTC)
mjgraves
I'm also interested in the bit rate of an NDI stream and a stream with alpha.
In the latest fun time video the quote the latency as being less than one frame, potentially as little as 16 lines. That implies that there's only intra-frame compression involved, so perhaps something MJPEG in nature.
Michael
sinc747
#4 Posted : Thursday, January 21, 2016 5:46:13 PM(UTC)
sinc747
Love this open NDI question thread.
Will NDI work over a wireless network. I know that it is intended for a Gigabit network, just curios if it would work wireless.
- Tom
PFBM
#5 Posted : Thursday, January 21, 2016 5:48:57 PM(UTC)
PFBM
- Tom
theoretically it can . if you have high speed stable wifi.
Cheers,
PFBM
ask
#6 Posted : Thursday, January 21, 2016 8:02:04 PM(UTC)
ask
It is designed to work over any IP network, but as Martin pointed out in the Live Show Q&A wireless speeds are variable, and so you may not be able to sustain a high bandwidth and stable signal all the time, and may top out at 400ish mps if you are lucky. Wired connectivity gives you the full 1 gig to play with. But I can think of a number of solutions that should help with this. I am really keen to get my hands on a working NDI based system and start testing different scenarios.
More on NDI here: https://player.vimeo.com/video/137855231
Quote from Newtek press release(Sept 2015):"NewTek worked closely with a large number of top manufacturers and developers to allow IP connectivity between devices. NDI’s backwards compatibility means that along with NewTek products and systems from Brainstorm, CasparCG, CharacterWorks, ChyronHego, ClassX, Compix, EasyWorship, Gnural Net, Graphics Outfitters, LiveXpert, Media 5, PlayBox Technology, Teradek, Vizrt, Wasp3D and many more will be NDI-enabled on the day of launch. NewTek has also collaborated with AJA, DELTACAST and Matrox to enable their capture cards to act as NDI senders or receivers; support for Blackmagic Design cards will also be provided. Boland, JVC, LiveU, NewsMaker, Panasonic, PESA, Sienna and Wowza are also working on providing NDI-based solutions."
thanks 2 users thanked ask for this useful post.
PFBM on 1/21/2016(UTC), madness on 1/22/2016(UTC)
Kelvin
#7 Posted : Thursday, January 21, 2016 9:09:01 PM(UTC)
Kelvin
How about an iOS and/or Android app to turn your phone into a wireless remote camera? Similar to the functionality of the Livestream.com App that works as a remote camera within the Livestream Studio software.
PFBM on 1/22/2016(UTC)
ask
#8 Posted : Friday, January 22, 2016 12:07:52 AM(UTC)
ask
Kelvin....great suggestion, for Newtek! Or one of its iOS/Adroid partners......
GeorgeR
#9 Posted : Friday, January 22, 2016 12:22:18 AM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
Just got to watch your January show. Great show, thanks.
If I got this right, NDI works within a local area network? And to use NDI with vMix you would need multiple vMix licenses?
Thanks in advance.
~George
thanks 1 user thanked GeorgeR for this useful post.
ask
#10 Posted : Friday, January 22, 2016 1:15:06 AM(UTC)
ask
Another NDI discussion:
and some context here: http://www.tvtechnology....e-ip-with-caution/277629
thanks 4 users thanked ask for this useful post.
GeorgeR on 1/22/2016(UTC), richardgatarski on 1/22/2016(UTC), madness on 1/22/2016(UTC), PFBM on 1/22/2016(UTC)
Innomedia
#11 Posted : Friday, January 22, 2016 3:20:48 AM(UTC)
Innomedia
Was thanked: 19 time(s) in 10 post(s)
I really appreciate this NDI discussion here because I believe this is something groundbreaking for future applications. Hopefully there will be some more information at ISE in Amsterdam next month. We will attend this show and try to get further details from participating companies like NewTek, Blackmagic, AJA and so on. We will keep you updated.
Regards
Karsten
thanks 2 users thanked Innomedia for this useful post.
richardgatarski on 1/22/2016(UTC), PFBM on 1/22/2016(UTC)
#12 Posted : Friday, January 22, 2016 9:56:45 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Some answers to some common questions below:
Is it GPU or CPU based?
NDI encoding/decoding is CPU based using around 5% per 1080p30 camera on a modern i7 CPU.
What color spaces are supported?
Frames are sent/received from NDI at 4:2:2 8 bit, but NDI compresses at 16 bit internally.
NDI also has full support for alpha, sent as a separate channel. (so 4:2:2:4)
Will there be converter boxes?
More than likely, possibly from more than one manufacturer.
We are working on our own prototypes using off the shelf SFF (small form factor) PCs, but
the codec can theoretically be used on devices as small as a standard HDMI to SDI mini converter.
The main advantage of one of these converters is you will no longer need a capture card
opening up most laptops to multi camera productions without the need for thunderbolt!
My hope is the converters will be affordable.
What is the stream bitrate?
To my knowledge it is variable bit rate.
I've seen around 50Mbps to 100Mbps per camera in my tests so far.
Will there be iOS and Android support?
Support for these devices, specifically the ARM processor is being worked on at NewTek.
Not sure if they will release software for these devices, but then NDI is open so if you are a developer
sign up for the SDK and start building your own!
Will Desktop Capture use NDI?
Yes, we plan to completely replace vMix Desktop Capture to use NDI.
NewTek will also release an app that does much the same thing.
What vMix licenses will we need?
One vMix license per PC that is running vMix at the same time.
If you use a 3rd party NDI app on a second PC or vMix Desktop Capture, you won't need the second license.
Do I need two copies of vMix to use capture cards from multiple PCs?
No. One of the cool things NewTek is working on is a universal PC app that can convert
any capture cards in the PC it is running from into NDI.
So you could have a vMix laptop in your studio and a rackmount PC with all the capture gear
locked away!
thanks 11 users thanked admin for this useful post.
jhebbel on 1/22/2016(UTC), madness on 1/22/2016(UTC), mjgraves on 1/22/2016(UTC), GeorgeR on 1/22/2016(UTC), SportsNetUSA.net on 1/22/2016(UTC), PFBM on 1/22/2016(UTC), sinc747 on 1/22/2016(UTC), DYosua on 1/22/2016(UTC), Lennart on 1/27/2016(UTC), VjMikey on 2/2/2016(UTC), lbgaus on 3/21/2016(UTC)
thecloudmediagroup
#13 Posted : Friday, January 22, 2016 12:46:15 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
Wow, this is a monumental feature.
I have a future project that would use NDI in a House of Worship setting for all their cameras. One computer would capture all inputs and cameras and then stream them over the network via NDI to another vMix machine. One machine is controlling the video in the sanctuary and the other machine is mixing the stream for the internet/foyer feed. Makes to live mixes easy. So many uses to list. Incredibly excited for this feature.
thanks 1 user thanked thecloudmediagroup for this useful post.
SportsNetUSA.net
#14 Posted : Friday, January 22, 2016 2:06:55 PM(UTC)
SportsNetUSA.net
Martin,
Thank you and your staff for all the work on incorporating NDI to vMix. It opens up so many possibilities.
thanks 3 users thanked SportsNetUSA.net for this useful post.
PFBM on 1/22/2016(UTC), GeorgeR on 1/22/2016(UTC), corporatejames on 1/22/2016(UTC)
PFBM
#15 Posted : Friday, January 22, 2016 2:28:06 PM(UTC)
PFBM
Will it work on OSX ?
how about a NDI multi recorder app ?
using another pc to record feeds ?
i imagined that it´s not GPU .... it can be quite complicated to code it..... :)
but Newtek should think about it .... co processing is very usefull to manage any system resources.
Cheers,
PFBM
mjgraves
#16 Posted : Friday, January 22, 2016 3:37:01 PM(UTC)
mjgraves
I'm not surprised that NDI doesn't tap the GPU specifically. Newtek's SDK can't assume that there's a specific sort of GPU capability available. The SDK is applicable to a variety of platforms.
I would imagine that someone incorporating NDI into an application that will be the primary load on a particular host could do their own optimization. That would be outside the realm of the SDK.
If Newtek are offering up an app to add NDI to common capture card we can hope that they will leverage whatever acceleration is available on those cards.
GeorgeR
#17 Posted : Friday, January 22, 2016 4:54:30 PM(UTC)
GeorgeR
Desktop Capture vs. NDI
It was said you plan to completely replace vMix Desktop Capture with NDI.
I love the Desktop Capture app. Use it in just about every video I do. Any chance you could keep the Desktop Capture app too?
Thanks,
~George
ask
#18 Posted : Friday, January 22, 2016 5:08:10 PM(UTC)
ask
GeorgeR. If my guess is right, DesktopCapture will remain pretty much the same as is, however the transport method will change to using NDI. Essentially the Desktop capture will become a source in the NDI selection screen.
Further, one of the features that NDI has natively is to serve any onscreen application as an NDI source. In my testing this works flawlessly and I cannot see any latency at all. Update: No discernible latency on the same PC. Also the same on a LAN. :-) So I am typing this on one machine but monitoring the output on a overhead projector connected to a PC across the room! I hope that NewTek is also talking to Cisco and Polycom etc!!!!
For those who are going to ask about Macs, NDI also provides support for Linux and OSX at this stage.....
thanks 3 users thanked ask for this useful post.
PFBM on 1/22/2016(UTC), mjgraves on 1/22/2016(UTC), GeorgeR on 1/22/2016(UTC)
theonlyboink
#19 Posted : Sunday, January 24, 2016 1:16:16 PM(UTC)
theonlyboink
Could you develop an add-on application for the single purpose just for capture/monitoring a single NDI signal/source? Like an aux output.
This could be very useful say in sports for commentators, time keeper, disturbution of a PGM feed in a venue etc.
This application would be free to run several computer within a network.
stevespaw
#20 Posted : Sunday, January 24, 2016 2:57:46 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
This is going to open up and new can of worms. :-)
Now I want 16 channels of audio in and out of vMix.
Greedy aren't I ? :-)
We use 8 channels+ in our facility now and it has kept vMix out of the loop for some of our uses. This could be VERY useful for us.
We use Dante to route audio also, and having 16 channels would be fantastic !!!
Steve
Similar Topics
Hardware Converter: SDI to NDI and DANTE Ethernet Card (Hardware Compatibility)
by blopes 6/10/2026 7:40:05 AM(UTC)
Excessive Source Drops, Render Drops, and Sync Issues with PTZOptics Studio 4K via NDI in vMix 29 (NDI)
by Matts887 6/2/2026 10:38:07 AM(UTC)
Powerpoint converter NDI/OMT (3rd Party Software and Development)
by mavik 5/22/2026 12:24:30 AM(UTC)
vMix Sees NDI Cameras, But Black Screen Using Them For Replay? (NDI)
by JohnDoe415 5/15/2026 8:59:28 PM(UTC)
Manufacturer claims OMT image quality is poorer than NDI? (OMT - Open Media Transport)
by jet 5/9/2026 3:27:36 PM(UTC)
Individual SRT Status (Feature Requests)
by alias 5/6/2026 2:18:12 AM(UTC)
how to force NDI HX3 capture (NDI)
by h2video.nl 4/8/2026 4:13:39 AM(UTC)
NDI hangs up (NDI)
by brianconverse 4/1/2026 6:45:00 AM(UTC)
Zoom Caller NDI OUT (Feature Requests)
by JDroadie 3/28/2026 1:04:52 AM(UTC)
Ptz NDI with vmix leggings (General Discussion)
by Almeida 3/26/2026 7:32:19 AM(UTC)
NDI routing on specific NIC (NDI)
by florinvg 3/8/2026 3:39:07 AM(UTC)
AUDIO mute toggle - what is the Event to indicate it is muted for an activator (General Discussion)
by Curtis Martin 2/28/2026 6:08:44 AM(UTC)
HDMI to NDI (NDI)
by MickeyMJJ 2/23/2026 7:31:02 PM(UTC)
Remote Control for BirdDog Play & NDI Studio Monitor (iOS & Android) (NDI)
Belarus youcci 2/18/2026 8:32:04 PM(UTC)
Play Outro Video When Ending Live Stream (General Discussion)
by bholland 2/16/2026 4:13:12 AM(UTC)
Source NDI view (Feature Requests)
by Srivelles 2/11/2026 6:13:15 PM(UTC)
fullscreen output NDI (Feature Requests)
by christianb 2/7/2026 8:21:10 AM(UTC)
NDI HX support for Output (Feature Requests)
by inquattro 2/4/2026 7:20:28 AM(UTC)
More External Destination please from 4 to 6 also with OMT and NDI (Feature Requests)
by inquattro 2/4/2026 7:17:57 AM(UTC)
Birddog XL Ultra Full NDI Crashes vMix (NDI)
by VVEPBrian 1/27/2026 9:48:11 AM(UTC)
Pulling Multiple Screen Shares as NDI Feeds (NDI)
by knbPixels 1/23/2026 4:37:16 AM(UTC)
NDI 6.x Discovery support (Feature Requests)
by fgolman 1/22/2026 2:56:09 PM(UTC)
NDI Audio Capture only (NDI)
by waxxel 1/14/2026 6:16:25 AM(UTC)
Need help with NDI into vMix via Tailscale (NDI)
by knbPixels 1/14/2026 2:46:15 AM(UTC)
Selection for image when loss of NDI stream (Feature Requests)
by fgolman 1/9/2026 5:50:08 AM(UTC)
NDI inputs 60 fps, Stream output 29.97 (NDI)
by Juke_Box 12/24/2025 7:58:29 AM(UTC)
Appending Title.gtzip PIP / Importing Data Source (GT)
by carl.cut4th 12/23/2025 2:40:08 AM(UTC)
NDI Output to Rodecaster Video (NDI)
by fcvideo 12/8/2025 4:29:10 AM(UTC)
Feature Request – Remote / API “magic link” reset for individual vMix Call inputs (Feature Requests)
by alancharman 12/2/2025 7:46:59 PM(UTC)
Sending a keypress to a browser source (General Discussion)
by Xperionbagel 11/27/2025 1:03:17 AM(UTC)
4 Pages123>»
