It is designed to work over any IP network, but as Martin pointed out in the Live Show Q&A wireless speeds are variable, and so you may not be able to sustain a high bandwidth and stable signal all the time, and may top out at 400ish mps if you are lucky. Wired connectivity gives you the full 1 gig to play with. But I can think of a number of solutions that should help with this. I am really keen to get my hands on a working NDI based system and start testing different scenarios. More on NDI here: https://player.vimeo.com/video/137855231Quote from Newtek press release(Sept 2015):"NewTek worked closely with a large number of top manufacturers and developers to allow IP connectivity between devices. NDI’s backwards compatibility means that along with NewTek products and systems from Brainstorm, CasparCG, CharacterWorks, ChyronHego, ClassX, Compix, EasyWorship, Gnural Net, Graphics Outfitters, LiveXpert, Media 5, PlayBox Technology, Teradek, Vizrt, Wasp3D and many more will be NDI-enabled on the day of launch. NewTek has also collaborated with AJA, DELTACAST and Matrox to enable their capture cards to act as NDI senders or receivers; support for Blackmagic Design cards will also be provided. Boland, JVC, LiveU, NewsMaker, Panasonic, PESA, Sienna and Wowza are also working on providing NDI-based solutions."
 2 users thanked ask for this useful post.
