Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
I thought about the very same: problems -may it be power supply or transfer speed- if on the same bus. But we've tested dozens of different port combinations. It was the same every time: black video on one or both. But each time we had an input in between when adding the second grabber ... it worked. Reproduced time and again.
So I'm not sure, but this seems to me like a problem with the inputs in vMix. Just an idea of one who doesn't know you code ... but could any index or pipe adress, or whatever, be chosen depending on the position of the input in the preview list?
The only thing I could think of is trying it on another laptop ... will do so in the next few days. But I don't think it will make any difference - I mean, we sat there for almost an hour, trying different orders, different ports, differnt input options. Nothing was working but the explain workaround. =/
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
mh166 wrote:I thought about the very same: problems -may it be power supply or transfer speed- if on the same bus. But we've tested dozens of different port combinations. It was the same every time: black video on one or both. But each time we had an input in between when adding the second grabber ... it worked. Reproduced time and again.
The only thing I could think of is trying it on another laptop ... will do so in the next few days. But I don't think it will make any difference - I mean, we sat there for almost an hour, trying different orders, different ports, differnt input options. Nothing was working but the explain workaround. =/ Did you try the running usbview.exe ? Perhaps you only have one USB hub available for USB ports.
mh166,
What cpu, memory and graphics card do you have?
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
I am trying to add an YouTube url as seen in the Help file in thefollowing format (http://www.youtube.com/v/VIDEO_ID ) It doesn't work. I get an error when I try to add the Flash module.
Thank you,
dundurs wrote: Another issue I came across: I wanted to assign a button to turn on/off sound of input1. To do that I created a keyboard shortcut with key: a, function: audio, duration: 1000, input: [input_name]. However when pressing "a", nothing happens. Perhaps Im doing something wrong? This would be very useful functionality in my case (to avoid using mouse).
Martin, is this a bug or Im just doing something wrong? Dundurs
ClementN,
What is the full URL you have typed into the Flash Input?
Thanks,
Martin vMix
Dundurs,
Yes this is a bug that will be fixed.
Martin vMix
Hello Martin, Here is the url as I tried to insert it: http://www.youtube.com/v/Y7ECkPxiqocadmin wrote:ClementN,
Thanks,
Martin vMix
On another computer, with vmix 7.3.0.50 it worked to insert the flash (with YouTube) module.
Now I do not know how to start the video . :)
Later edit: nevermind. I just clicked on the image and started to play :)
(I was expecting the play ">" sign under the Program and Preview windows to work here)
