4 Pages«<234
mh166
#61 Posted : Friday, May 18, 2012 8:42:50 AM(UTC)
mh166
I thought about the very same: problems -may it be power supply or transfer speed- if on the same bus. But we've tested dozens of different port combinations. It was the same every time: black video on one or both. But each time we had an input in between when adding the second grabber ... it worked. Reproduced time and again.
So I'm not sure, but this seems to me like a problem with the inputs in vMix. Just an idea of one who doesn't know you code ... but could any index or pipe adress, or whatever, be chosen depending on the position of the input in the preview list?
The only thing I could think of is trying it on another laptop ... will do so in the next few days. But I don't think it will make any difference - I mean, we sat there for almost an hour, trying different orders, different ports, differnt input options. Nothing was working but the explain workaround. =/
dundurs
#62 Posted : Friday, May 18, 2012 10:54:58 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
Did you try the running usbview.exe ? Perhaps you only have one USB hub available for USB ports.
#63 Posted : Friday, May 18, 2012 11:12:59 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
mh166,
What cpu, memory and graphics card do you have?
ClementN
#64 Posted : Sunday, May 20, 2012 10:00:45 AM(UTC)
ClementN
Romania
I am trying to add an YouTube url as seen in the Help file in thefollowing format (http://www.youtube.com/v/VIDEO_ID )
It doesn't work. I get an error when I try to add the Flash module.
Thank you,
dundurs
#65 Posted : Sunday, May 20, 2012 11:18:16 AM(UTC)
dundurs
dundurs wrote:
Another issue I came across:
I wanted to assign a button to turn on/off sound of input1. To do that I created a keyboard shortcut with key: a, function: audio, duration: 1000, input: [input_name]. However when pressing "a", nothing happens. Perhaps Im doing something wrong? This would be very useful functionality in my case (to avoid using mouse).
Martin, is this a bug or Im just doing something wrong?
Dundurs
#66 Posted : Sunday, May 20, 2012 9:51:52 PM(UTC)
ClementN,
What is the full URL you have typed into the Flash Input?
Thanks,
#67 Posted : Sunday, May 20, 2012 9:52:12 PM(UTC)
Dundurs,
Yes this is a bug that will be fixed.
dundurs on 5/20/2012(UTC)
#68 Posted : Monday, May 21, 2012 5:25:08 AM(UTC)
The final v3 version has been release:
http://www.vmix.com.au/download.aspx
ClementN
#69 Posted : Monday, May 21, 2012 3:20:24 PM(UTC)
ClementN
Romania
Hello Martin,
Here is the url as I tried to insert it:
http://www.youtube.com/v/Y7ECkPxiqoc
admin wrote:
ClementN,
Thanks,
ClementN
#70 Posted : Wednesday, May 23, 2012 5:00:24 AM(UTC)
ClementN
Romania
On another computer, with vmix 7.3.0.50 it worked to insert the flash (with YouTube) module.
Now I do not know how to start the video . :)
Later edit: nevermind. I just clicked on the image and started to play :)
(I was expecting the play ">" sign under the Program and Preview windows to work here)
4 Pages«<234
