fenki86
#1 Posted : Monday, June 15, 2015 2:06:51 PM(UTC)
fenki86
Anyone using vMix with a Macbook Pro? We are thinking of getting one to use vMix via Bootcamp. Thunderbolt just gives us more opportunities for our 1-2 camera setup.
Thanks for any feedback.
Speegs
#2 Posted : Tuesday, June 16, 2015 12:51:14 AM(UTC)
Speegs
Yes works great, I have 2 x MacBook Pros (both Quad Core i7) doing this (One with Iris Pro 5200 and the other more expensive with NVidia). Currently running Windows 7 via Bootcamp. (not really interested in Windows 8). I went with MacbookPro as was using Black Magic capture equipment and found usb3 unreliable (no inbuilt scaler and drivers were working and then not, a single Windows or VMix update = headache for me). Since moved back to usb3, but found Magewell equipment reliable and no headaches as they are driver less on the usb3 models.
We are also using a thunderbolt 2 docking solution to get 3 extra usb 3 ports, plus lan from one thunderbolt 2 port..
I find myself using the Mac Partition for browsing and anything else. The Windows/Vmix partition for doing that job. The top end MacBook Pros actually have very good hardware inside them and a lovely display.
I've run 3 full HD inputs and streamed using FFMPEG from this setup. All usb3 magewell capture devices. I think it could do 4 maybe on the ever so slightly faster MacbookPro, but was pushing the limits of the Iris Pro 5200 model with 3 inputs.
Now more laptops have thunderbolt 2 ports available I'm not sure I would buy a MacbookPro again for Vmix. So far however it really has been a solid laptop for about $2-3k (on special) .. As most people say get the best one you can afford. Don't use the dual cores unless your needs are basic, you will run out of grunt, I tried for a while as I wanted a 13", but it got another job after 2 months of Vmixing.
New Top End has switch graphics card to:
AMD Radeon R9 M370X with 2GB of GDDR5 memory
Note: I'm using the models prior with Iris Pro 5200 only and the NVIDIA GeForce GT 750M, no idea if the Radeon would be better or worse.
Speegs
LucidSamples
#3 Posted : Tuesday, June 23, 2015 4:06:28 AM(UTC)
LucidSamples
on my macbook air it works well :)
Speegs
#4 Posted : Tuesday, June 23, 2015 6:50:03 AM(UTC)
Speegs
How many full hd inputs do you get away with?
fenki86
#5 Posted : Tuesday, June 23, 2015 9:39:37 AM(UTC)
fenki86
thanks for your help... as I am going to use it for a 1-2 camera setup it looks like a Macbook should be great to run vMix and suit my needs. :-)
Similar Topics
Recommendations for eGPU for MacBook Pro running Bootcamp partition (Hardware Compatibility)
by NYCAustin 2/9/2021 8:03:31 AM(UTC)
Macbook Pro or AlienWare? Wirecast or vMix? AJA or BlackMagic capture/PCI Thunderbolt 3? (General Discussion)
by EvilAsh80 9/29/2020 5:35:11 AM(UTC)
Hardware encoding on MacBook Pro (Hardware Compatibility)
by paulzenk 3/31/2020 11:21:24 AM(UTC)
Thunderbolt Adapters and MacBook Pro performance (Hardware Compatibility)
by icm1812 10/22/2019 7:35:25 AM(UTC)
vMix, Bootcamp (MacBook Pro - Retina) & Magewell (Systems)
by avinhouse 3/9/2018 2:27:52 AM(UTC)
MacBook Pro - boot camp - 4 hdmi inputs (Hardware Compatibility)
by Torg 12/31/2017 7:29:10 AM(UTC)
Ultrastudio HD mini on Macbook Pro with Thunderbolt 2 (Hardware Compatibility)
by rinaldo 7/10/2017 9:35:10 AM(UTC)
Running under fusion? Macbook pro (Systems)
by G3racingMike 12/7/2016 8:32:08 AM(UTC)
MacBook Pro Option (Hardware Compatibility)
by solo16 3/9/2016 11:00:06 AM(UTC)
MacBook Pro with two BMD UltraStudio Mini Recorders (Hardware Compatibility)
by FAndreas 11/27/2015 1:40:35 PM(UTC)
Macbook pro and vMix (Hardware Compatibility)
by geniusweb 9/21/2015 12:41:34 PM(UTC)
New MacBook Pro with the AMD Radeon R9 M370X Processor ...worth getting ? (Hardware Compatibility)
by BigApple 6/2/2015 9:23:34 AM(UTC)
Macbook Pro retina with Windows 7 sufficient for HD streaming? (Hardware Compatibility)
by jip 2/10/2014 2:01:59 PM(UTC)
What's needed to connect two hd camcorders to a Macbook Pro? (General Discussion)
by douglashoover 11/27/2013 2:46:17 AM(UTC)
