Joined: 6/6/2015(UTC) Posts: 21 Location: South Africa
Hi Guys,
I've really enjoying the VMix Replay. It's working fairly well on my system.
What does not work for my application is the audio. I can't get audio follow video on the replays? Pitch-side cameras will have different audio to the wide shot for example, and that isn't recorded, either on the streams isos, or available for playback on the replay.
Is there a checkbox somewhere that i'm missing, or is this currently not possible?
@ Kibim
AFAIK, there is only one audio source recorded across all replay camera angles that is set when you first set-up your "Replay" session. (one particular camera or 'Master audio') Audio from the "Replay" input is then controlled the same way as with any other input with audio. If you are looking to record the audio from all camera angles, you may have to look into using the "Video Delay" or "MultiCorder" features, which are not quite the same as the "Replay" feature. If those options don't meet your need, I would suggest putting in a 'Feature Request'.
Thanks IceStream,
Where do i put in the feature request? Can't seem to find the thread
*edit : nevermind, i found it.
