curtismacd31
#1 Posted : Saturday, January 13, 2024 6:21:44 AM(UTC)
curtismacd31
Hi All, I recently had a project where I had to get Nat's sound from the camera and program sound embedded onto a single clip and the only way I could find to do this was to export the clip with audio set to "Camera 4" (which in this case is program), then export the clip again with audio set to follow. This game me both audio channels I was looking for I just needed to take the clips into the NLE and put the audio channels on separate channels and export again.
It would be a nice feature if you could select different camera input audio and assign them to a channel.
for example, Channel 1 - Camera 4, Channel 2 - Camera 1.
Maybe there is a way to do this already.
