Kibim
#1 Posted : Saturday, June 6, 2015 10:58:51 AM(UTC)
Kibim
Hi Guys,
I've really enjoying the VMix Replay. It's working fairly well on my system.
What does not work for my application is the audio. I can't get audio follow video on the replays? Pitch-side cameras will have different audio to the wide shot for example, and that isn't recorded, either on the streams isos, or available for playback on the replay.
Is there a checkbox somewhere that i'm missing, or is this currently not possible?
#2 Posted : Saturday, June 6, 2015 12:36:27 PM(UTC)
@ Kibim
AFAIK, there is only one audio source recorded across all replay camera angles that is set when you first set-up your "Replay" session. (one particular camera or 'Master audio')
Audio from the "Replay" input is then controlled the same way as with any other input with audio.
If you are looking to record the audio from all camera angles, you may have to look into using the "Video Delay" or "MultiCorder" features, which are not quite the same as the "Replay" feature.
If those options don't meet your need, I would suggest putting in a 'Feature Request'.
Kibim
#3 Posted : Thursday, June 18, 2015 4:56:01 AM(UTC)
Kibim
Thanks IceStream,
Where do i put in the feature request? Can't seem to find the thread
*edit : nevermind, i found it.
Similar Topics
Replay Audio Export Mapping (Feature Requests)
by curtismacd31 1/13/2024 6:21:44 AM(UTC)
Instant replay audio only on firts part (Instant Replay)
by Laky 3/18/2021 11:05:53 PM(UTC)
Audio Input as Replay Audio Source (Feature Requests)
by slxxi 6/22/2020 10:58:25 PM(UTC)
Instant Replay Audio selection (Feature Requests)
by xaver 2/25/2020 11:45:10 PM(UTC)
Shortcut to change replay audio selection (Feature Requests)
by StryderTV 10/10/2019 5:18:13 PM(UTC)
Instant Replay Audio Source (Feature Requests)
by xaver 9/30/2019 8:52:15 PM(UTC)
Option to Mute Replay Audio when not at 100% (Feature Requests)
by Radiotvpat1982 6/28/2019 6:17:17 AM(UTC)
Instant Replay Audio request (Feature Requests)
by jvphobic 1/26/2018 10:41:41 AM(UTC)
Instant Replay Audio (Instant Replay)
by jvphobic 1/25/2018 6:50:30 PM(UTC)
Replay Audio Source BUG (Instant Replay)
by xaver 11/27/2017 5:04:27 AM(UTC)
Instant Replay Audio Choice (Instant Replay)
by jvphobic 8/4/2017 2:02:16 PM(UTC)
Replay audio source (Feature Requests)
by loganwhite 6/6/2017 6:52:17 PM(UTC)
Shortcut function to change Replay Audio source (Feature Requests)
by lbgaus 11/26/2016 7:57:40 PM(UTC)
Probably bug in instant replay audio strip configuration? (Instant Replay)
Belarus pm 11/8/2016 5:33:06 AM(UTC)
Instant Replay Audio Channels (Feature Requests)
by Kibim 6/18/2015 5:01:09 AM(UTC)
