elshorbagy
#1 Posted : Monday, March 30, 2015 10:10:34 AM(UTC)
elshorbagy
I would like to know how can I display the vmix video to an external HDMI screen.I tried many times but no luck. Please advice.
Thank you
#2 Posted : Monday, March 30, 2015 1:15:45 PM(UTC)
@ elshorbagy
There are basically two options available:
1. From your graphics card (if so equipped)
2. From an I/O expansion card or device
This is directly from the help page on www.vmixhd.com:
Output:
Output 4 formats simultaneously (Screen, File, External Renderer, Streaming)
Default output to secondary computer display or projector
Optional output to compatible rendering device such as the Blackmagic Design Intensity Pro
Output to streaming applications such as the Adobe Flash Media Live Encoder
Output to web sites such as USTREAM and YouTube Live
Probably not much help, but the bottom line is how is you computer equipped?
Do you have HDMI out capabilities?
tdurhamjr
#3 Posted : Wednesday, April 1, 2015 3:46:25 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
elshorbagy wrote:
Thank you
Read this and see if it helps you.
http://forums.vmix.com.a....aspx?g=posts&t=3535
Tim
Similar Topics
Blackmagic Decklink Quad HDMI returns Unsupported Video Format (Hardware Compatibility)
by wassers 5/23/2025 6:14:11 PM(UTC)
HDMI fullscreen output looks unsharp (and how I solved it) (General Discussion)
by Pepsi(~) 5/23/2025 1:58:39 AM(UTC)
HDMI capture dongle disconnects when VMix closed (Hardware Compatibility)
by congoblue 1/14/2025 1:55:13 AM(UTC)
External HDMI capture card for a PC? (Hardware Compatibility)
by clipads 12/16/2024 3:00:21 AM(UTC)
HDMI Pixelation Issues with USB Capture Device (Hardware Compatibility)
by ubm 3/26/2024 10:06:56 AM(UTC)
Blackmagic Decklink Quad HDMI Recorder give massive delay after adding more than 2 source (Hardware Compatibility)
by khmerbrave 11/20/2023 9:20:21 PM(UTC)
Seperate Audio Out to the HDMI out? (General Discussion)
by buntonn 4/19/2023 6:56:43 AM(UTC)
HDMI to USB to output to web cam (Hardware Compatibility)
by jameshallspanner 3/2/2023 11:39:19 PM(UTC)
Double Blackmagic Quad HDMI Setup? (Hardware Compatibility)
by WONGthink 2/23/2023 7:05:40 AM(UTC)
Multiple HDMI cam inputs to laptop (Hardware Compatibility)
by pesi 8/14/2022 6:02:51 AM(UTC)
NDI monitor VS YouTube VS ReStream VS HDMI Out (NDI)
by Fbcgulfport 7/11/2022 9:31:40 AM(UTC)
BMD decklink quad HDMI recorder capture card (Hardware Compatibility)
by Cindy Drozda 4/26/2022 9:17:18 AM(UTC)
x4 HDMI Inputs on Laptop (Hardware Compatibility)
by SeanLP 3/12/2022 1:12:32 AM(UTC)
HDMI or NDI (NDI)
by JohnnyBG 1/6/2022 8:46:15 PM(UTC)
HDMI Output to Teradeck Wave (Hardware Compatibility)
by fingerlakes1 11/30/2021 7:58:28 AM(UTC)
Quad HDMI 4K capture into vMix (Hardware Compatibility)
by Cindy Drozda 11/16/2021 5:58:48 AM(UTC)
Capture Multiple HDMI video cams (Hardware Compatibility)
by pesi 10/2/2021 6:46:40 AM(UTC)
2-way HDMI + 2-way SDI half height acquisition card (Showcase)
by lpslxs 8/19/2021 4:00:25 PM(UTC)
Using vMix on a laptop with HDMI monitor (General Discussion)
by Bob Brazner 8/5/2021 12:07:52 PM(UTC)
Unreliable HDMI spit from GeForce 1660 (Hardware Compatibility)
by RobertL 6/16/2021 11:18:08 PM(UTC)
AJA KONA HDMI or Blackmagic Design DeckLink Quad HDMI (Hardware Compatibility)
by Bodo 6/16/2021 10:30:47 PM(UTC)
Low-cost HDMI capture (Hardware Compatibility)
by jlarson 6/7/2021 5:57:43 PM(UTC)
Black Magic Design Quad HDMI vs Mageweall Quad HDMI (Hardware Compatibility)
by jammerxd 6/5/2021 5:13:54 AM(UTC)
DeckLink Mini Monitor 4K - 8 channels hdmi audio out? (Hardware Compatibility)
by andreypetr 4/26/2021 10:34:09 PM(UTC)
Magewell USB / HDMI capture embedded audio problem (Hardware Compatibility)
by Jason Vaughan 4/25/2021 6:56:45 AM(UTC)
VMIX with HDMI Transmitter (General Discussion)
by joei 3/16/2021 10:52:43 PM(UTC)
Multiple HDMI to USB 2.0 sources (Hardware Compatibility)
by brucecopes 3/9/2021 5:59:56 AM(UTC)
AUDIO OUTPUT BUS A set to HDMI but doesn't work (General Discussion)
by Jeffry_Ghost 3/3/2021 8:18:40 PM(UTC)
Alpha channel by HDMI cable (General Discussion)
by Gabriel Mewes 3/3/2021 12:12:29 AM(UTC)
Acquisition card that can collect HDMI and SDI (Showcase)
by lpslxs 3/1/2021 1:24:47 AM(UTC)
