Joined: 1/5/2014(UTC) Posts: 26 Location: Sanford, NC
When building a computer to use vMix on, what is the most important component for good video quality? I am using a Quad core processor with 4 GB RAM, GeForce FX 1300 video card and 2 Osprey 210 cards with the breakout cable. vMix works perfectly, but the video quality is not that great and if I try to record to the hard drive, I get intermittent streaks across the video. Thanks for your help. Wynn
@ wkrasley Do you mean the Quadro FX 1300? The Video card is one of the "most important components" for reliable and smooth video performance with vMix and I would suggest that your card is slightly below the 'recommended' requirements given it is rated below the GeForce 210 which is not quite up to the minimum supported specs of the Nvidea 250: http://www.vmixhd.com/supported-hardware.aspxIce
Thanks Ice. I will look at getting a EVGA NVIDIA GeForce GTS 450.
Wynn
