jpeg2RAW
#1 Posted : Wednesday, October 29, 2014 8:09:24 AM(UTC)
jpeg2RAW
My broadcast machine is a Core i7 3770k overcocked to 4.2Ghz with a ATI Radeon 7850. For capture cards, the machine has 2 AverMedia C985 cards getting an HDMI 1080p feed from two other computers. There are also two Logitech C920 webcams attached to the broadcast machine, both running at 1080p.
With vMix sitting idle (ie, not streaming, recording) I am getting a Render time under 10ms. However, once I start recording & streaming the render time bounces between 13+/- to 35+/-. And then I open Skype and give it the vMix External feed as it's camera and now the render time bounces between 50+/- and over 100.
I thought the Radeon 7850 was a pretty powerful card, but it appears I need something much stronger. Any suggestions?
#2 Posted : Wednesday, October 29, 2014 8:21:54 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Check your settings against the Optimal Settings section here:
http://www.vmixhd.com/knowledgebase/article.aspx/32/optimising-performance
If everything is fine, try setting things up without any cameras added.
I have seen the C920 do all sorts of strange things on some systems including increasing the render time.
7850 is certainly fast enough to do what you're running.
Also check your CPU usage in vMix when recording.
Similar Topics
Laggy High Render Times. Upgrade help? (Hardware Compatibility)
by Lastmarine 5/13/2025 7:05:19 PM(UTC)
Render times and NDI (NDI)
by nomski 11/18/2022 8:37:59 AM(UTC)
Higher render times if vMix application on foreground? (General Discussion)
by jip 7/17/2021 12:04:59 AM(UTC)
High render times (NDI)
by TimCac 12/15/2020 3:23:52 AM(UTC)
Recording Glitch - 1 FPS Recording - Streams/Render Times Normal (General Discussion)
by Jamesdtl 12/10/2020 11:59:33 AM(UTC)
High Render Times with 2 Outputs (General Discussion)
by Slaver 11/25/2020 10:16:21 PM(UTC)
New Dell G7s i7-10750H RTX 2070-Max Q high render times (General Discussion)
by Vince Beck 8/13/2020 3:43:33 AM(UTC)
High render times after vmix 23.0.0.49 update (General Discussion)
by Dune 4/11/2020 12:11:57 PM(UTC)
High Render Times / Dropping Frames (General Discussion)
by kgoodyer 5/5/2019 9:56:39 AM(UTC)
Render Times Bouncing (General Discussion)
by kbrnhart 2/7/2019 12:29:20 AM(UTC)
GPU Overload and Long Render Times (Hardware Compatibility)
by JohnnyFlash 11/1/2018 8:24:54 AM(UTC)
Hi render times even with blank session (General Discussion)
by nowski 12/2/2017 1:41:48 PM(UTC)
Windows 10 Fall Creators Render Times *FIXED* (General Discussion)
by floz23 10/25/2017 1:25:11 PM(UTC)
High render times + FPS drops. CPU & GPU usage are low. Help? (General Discussion)
by RandomStreamer 5/19/2017 9:08:19 AM(UTC)
Laptop Render Times (General Discussion)
by Michail 1/6/2017 9:46:02 AM(UTC)
