JW
#1 Posted : Sunday, June 25, 2017 5:46:23 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
Hi all,
My request is a trigger when vMix is started and fully loaded so that the recording or streaming can be started unattended.
I did a lot of searching and I know it is possible to start streaming with a batchfile, but that is in my opinion not a very elegant way to do things.
There are proponents and opponents for an auto streaming of auto recording feature option, but with a trigger everyone can do his/her own thing.
thanks 1 user thanked JW for this useful post.
G3racingMike on 12/3/2018(UTC)
Ronald555
#2 Posted : Tuesday, August 14, 2018 7:46:15 AM(UTC)
Ronald555
+1
I like to send a few shortcuts when vMix starts.
(for example start vMix with another input category then the 'all inputs'one)
Using a script is not an elegant method because sometimes vMix starts quickly and sometimes it take almost a minute.
So the script always has to wait a minute.
thanks 1 user thanked Ronald555 for this useful post.
BBLive
#3 Posted : Friday, January 10, 2020 4:18:21 AM(UTC)
BBLive
+1
Would love for vMix to be able to start streaming after launch.
#4 Posted : Saturday, February 20, 2021 7:43:42 PM(UTC)
Ian H. on FB came up with a neat solution:
Have a browserinput set to a httprequest function to start a shortcut or a script
Something like http://127.0.0.1:8088/api/?Function=ScriptStart&Value=scriptname as link
Will perform the function each time a preset containing such input is loaded!
thanks 5 users thanked doggy for this useful post.
dmwkr on 3/3/2021(UTC), gpdipalmerahtimur on 6/19/2023(UTC), Mano Bakker on 8/28/2023(UTC), AngusFindlay on 8/1/2024(UTC), TL68 on 2/26/2026(UTC)
Peter1000
#5 Posted : Thursday, June 3, 2021 6:30:07 PM(UTC)
Peter1000
Switzerland
Was thanked: 86 time(s) in 66 post(s)
+1 shortcut or script
gpdipalmerahtimur
#6 Posted : Monday, June 19, 2023 12:12:29 AM(UTC)
gpdipalmerahtimur
Indonesia
+1
TL68
#7 Posted : Thursday, February 26, 2026 11:31:30 PM(UTC)
TL68
Sweden
+1
TBacker
#8 Posted : Wednesday, October 7, 2026 1:56:31 AM(UTC)
TBacker
Bump. Again.
x10 because the browser input script command workaround no longer works.
Two triggers are needed:
Preset load started (before inputs are added / configured by the load process)
Preset load complete (after load is complete and the software is "ready for work")
thanks 1 user thanked TBacker for this useful post.
TL68 on 10/9/2026(UTC)
knbPixels
#9 Posted : Wednesday, October 7, 2026 4:41:35 AM(UTC)
knbPixels
+1
TL68
#10 Posted : Friday, October 9, 2026 12:46:05 AM(UTC)
TL68
Sweden
+1 again!
Harness
#11 Posted : Tuesday, October 13, 2026 8:02:25 PM(UTC)
Harness
There is a way to do this in Companion with triggers looking at the connection status, however, it would be nice to have this built into vMix itself.
+1
TBacker
#12 Posted : Wednesday, October 14, 2026 2:41:40 AM(UTC)
TBacker
+1
Yes, but it's a bit kludgey for some things as the preset change trigger seems to happen with varying delay. Had to build in a long delay to accommodate varying preset load times for post-load work. It would be far better for vMix to generate it's own internal triggers as the first / last step in any preset loading sequence. Obviously if someone wanted a script to run before preset load it would need to be a global script, and the preset loading code would need to wait for the script execution to complete (or exit).
