Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
Hi all,
My request is a trigger when vMix is started and fully loaded so that the recording or streaming can be started unattended.
I did a lot of searching and I know it is possible to start streaming with a batchfile, but that is in my opinion not a very elegant way to do things. There are proponents and opponents for an auto streaming of auto recording feature option, but with a trigger everyone can do his/her own thing.
 1 user thanked JW for this useful post.
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
+1
I like to send a few shortcuts when vMix starts. (for example start vMix with another input category then the 'all inputs'one)
Using a script is not an elegant method because sometimes vMix starts quickly and sometimes it take almost a minute. So the script always has to wait a minute.
 1 user thanked Ronald555 for this useful post.
Joined: 11/9/2019(UTC) Posts: 6  Was thanked: 1 time(s) in 1 post(s)
+1 Would love for vMix to be able to start streaming after launch.
Ian H. on FB came up with a neat solution: Have a browserinput set to a httprequest function to start a shortcut or a script Something like http://127.0.0.1:8088/api/?Function=ScriptStart&Value=scriptname as link Will perform the function each time a preset containing such input is loaded!
 5 users thanked doggy for this useful post.
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Joined: 12/8/2022(UTC) Posts: 168  Thanks: 52 times Was thanked: 3 time(s) in 3 post(s)
Joined: 10/29/2019(UTC) Posts: 105  Location: Syracuse Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
Bump. Again.
x10 because the browser input script command workaround no longer works.
Two triggers are needed: Preset load started (before inputs are added / configured by the load process) Preset load complete (after load is complete and the software is "ready for work")
 1 user thanked TBacker for this useful post.
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Joined: 9/3/2021(UTC) Posts: 10  Location: LONDON Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
There is a way to do this in Companion with triggers looking at the connection status, however, it would be nice to have this built into vMix itself.
+1
Originally Posted by: Harness  There is a way to do this in Companion with triggers looking at the connection status, however, it would be nice to have this built into vMix itself.
+1 Yes, but it's a bit kludgey for some things as the preset change trigger seems to happen with varying delay. Had to build in a long delay to accommodate varying preset load times for post-load work. It would be far better for vMix to generate it's own internal triggers as the first / last step in any preset loading sequence. Obviously if someone wanted a script to run before preset load it would need to be a global script, and the preset loading code would need to wait for the script execution to complete (or exit).
Thanks: 14 times Was thanked: 1 time(s) in 1 post(s)
+1 Originally Posted by: JW  Hi all,
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
+1 Also would like trigger to work no matter if video or source is in program out, even if video is in preview or just playing out to assigned output, if there is a trigger listed it should activate or function.
+1 I would also appreciate having this feature.
