JW
#1 Posted : Sunday, June 25, 2017 5:46:23 AM(UTC)
JW
Was thanked: 8 time(s) in 7 post(s)
Hi all,
My request is a trigger when vMix is started and fully loaded so that the recording or streaming can be started unattended.
I did a lot of searching and I know it is possible to start streaming with a batchfile, but that is in my opinion not a very elegant way to do things.
There are proponents and opponents for an auto streaming of auto recording feature option, but with a trigger everyone can do his/her own thing.
thanks 1 user thanked JW for this useful post.
G3racingMike on 12/3/2018(UTC)
Ronald555
#2 Posted : Tuesday, August 14, 2018 7:46:15 AM(UTC)
Ronald555
+1
I like to send a few shortcuts when vMix starts.
(for example start vMix with another input category then the 'all inputs'one)
Using a script is not an elegant method because sometimes vMix starts quickly and sometimes it take almost a minute.
So the script always has to wait a minute.
thanks 1 user thanked Ronald555 for this useful post.
BBLive
#3 Posted : Friday, January 10, 2020 4:18:21 AM(UTC)
BBLive
+1
Would love for vMix to be able to start streaming after launch.
#4 Posted : Saturday, February 20, 2021 7:43:42 PM(UTC)
Ian H. on FB came up with a neat solution:
Have a browserinput set to a httprequest function to start a shortcut or a script
Something like http://127.0.0.1:8088/api/?Function=ScriptStart&Value=scriptname as link
Will perform the function each time a preset containing such input is loaded!
thanks 5 users thanked doggy for this useful post.
dmwkr on 3/3/2021(UTC), gpdipalmerahtimur on 6/19/2023(UTC), Mano Bakker on 8/28/2023(UTC), AngusFindlay on 8/1/2024(UTC), TL68 on 2/26/2026(UTC)
Peter1000
#5 Posted : Thursday, June 3, 2021 6:30:07 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
+1 shortcut or script
gpdipalmerahtimur
#6 Posted : Monday, June 19, 2023 12:12:29 AM(UTC)
gpdipalmerahtimur
Indonesia
+1
TL68
#7 Posted : Thursday, February 26, 2026 11:31:30 PM(UTC)
TL68
Sweden
+1
TBacker
#8 Posted : Wednesday, October 7, 2026 1:56:31 AM(UTC)
TBacker
Bump. Again.
x10 because the browser input script command workaround no longer works.
Two triggers are needed:
Preset load started (before inputs are added / configured by the load process)
Preset load complete (after load is complete and the software is "ready for work")
thanks 1 user thanked TBacker for this useful post.
TL68 on 10/9/2026(UTC)
knbPixels
#9 Posted : Wednesday, October 7, 2026 4:41:35 AM(UTC)
knbPixels
+1
TL68
#10 Posted : Friday, October 9, 2026 12:46:05 AM(UTC)
TL68
Sweden
+1 again!
Harness
#11 Posted : Tuesday, October 13, 2026 8:02:25 PM(UTC)
Harness
There is a way to do this in Companion with triggers looking at the connection status, however, it would be nice to have this built into vMix itself.
+1
TBacker
#12 Posted : Wednesday, October 14, 2026 2:41:40 AM(UTC)
TBacker
+1
Yes, but it's a bit kludgey for some things as the preset change trigger seems to happen with varying delay. Had to build in a long delay to accommodate varying preset load times for post-load work. It would be far better for vMix to generate it's own internal triggers as the first / last step in any preset loading sequence. Obviously if someone wanted a script to run before preset load it would need to be a global script, and the preset loading code would need to wait for the script execution to complete (or exit).
djmoll
#13 Posted : Thursday, October 15, 2026 1:58:54 PM(UTC)
djmoll
+1
Originally Posted by: JW Go to Quoted Post
Hi all,
Egriswold
#14 Posted : Friday, October 30, 2026 10:37:43 AM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
+1
Also would like trigger to work no matter if video or source is in program out, even if video is in preview or just playing out to assigned output, if there is a trigger listed it should activate or function.
djmoll
#15 Posted : Friday, October 30, 2026 1:35:03 PM(UTC)
djmoll
+1
I would also appreciate having this feature.
Guest (5)
