Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
Hi all,
My request is a trigger when vMix is started and fully loaded so that the recording or streaming can be started unattended.
I did a lot of searching and I know it is possible to start streaming with a batchfile, but that is in my opinion not a very elegant way to do things. There are proponents and opponents for an auto streaming of auto recording feature option, but with a trigger everyone can do his/her own thing.
 1 user thanked JW for this useful post.
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
+1
I like to send a few shortcuts when vMix starts. (for example start vMix with another input category then the 'all inputs'one)
Using a script is not an elegant method because sometimes vMix starts quickly and sometimes it take almost a minute. So the script always has to wait a minute.
 1 user thanked Ronald555 for this useful post.
Joined: 11/9/2019(UTC) Posts: 6  Was thanked: 1 time(s) in 1 post(s)
+1 Would love for vMix to be able to start streaming after launch.
Ian H. on FB came up with a neat solution: Have a browserinput set to a httprequest function to start a shortcut or a script Something like http://127.0.0.1:8088/api/?Function=ScriptStart&Value=scriptname as link Will perform the function each time a preset containing such input is loaded!
 5 users thanked doggy for this useful post.
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 86 time(s) in 66 post(s)
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Joined: 12/8/2022(UTC) Posts: 167  Thanks: 51 times Was thanked: 3 time(s) in 3 post(s)
Joined: 10/29/2019(UTC) Posts: 101  Location: Syracuse Thanks: 10 times Was thanked: 5 time(s) in 4 post(s)
Bump. Again.
x10 because the browser input script command workaround no longer works.
Two triggers are needed: Preset load started (before inputs are added / configured by the load process) Preset load complete (after load is complete and the software is "ready for work")
 1 user thanked TBacker for this useful post.
Joined: 2/7/2024(UTC) Posts: 194  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Joined: 9/3/2021(UTC) Posts: 10  Location: LONDON Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
There is a way to do this in Companion with triggers looking at the connection status, however, it would be nice to have this built into vMix itself.
+1
