2 Pages<12
JacobLarsson
#21 Posted : Tuesday, November 25, 2025 10:28:15 PM(UTC)
JacobLarsson
Norway
+1
thanks 1 user thanked JacobLarsson for this useful post.
jet on 11/25/2025(UTC)
eddysangalli
#22 Posted : Tuesday, November 25, 2025 11:23:30 PM(UTC)
eddysangalli
Brazil
+1
thanks 1 user thanked eddysangalli for this useful post.
jet on 11/26/2025(UTC)
Justingonz
#23 Posted : Wednesday, December 3, 2025 2:41:08 PM(UTC)
Justingonz
+1
thanks 1 user thanked Justingonz for this useful post.
jet on 12/3/2025(UTC)
mavik
#24 Posted : Wednesday, December 3, 2025 5:18:24 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
+1
JarkkoRx
#25 Posted : Saturday, January 31, 2026 9:20:14 PM(UTC)
JarkkoRx
Finland
I have bumped into a problem that would be solved by 10 bit output.
In ST2110, I have noticed that many of the devices only support 10 bit, and fail with 8 bit.
I'm testing Decklink IP card with vMix, and this is the case currently with many ST2110 receivers.
I'm working around this issue with CasparCG, which outputs 10 bit to Decklink and just takes vMix NDI output to the Decklink.
So basically, this case would be solved by just converting 8 bit to 10 bit in the name on compatibility, not in the name of picture quality :)
I know my idea is bad and will not support the efforts of the community trying to get real 10 bit output.
thanks 1 user thanked JarkkoRx for this useful post.
jet on 7/6/2026(UTC)
mavik
#26 Posted : Monday, February 2, 2026 6:06:15 AM(UTC)
mavik
Are you testing with the BMD 100G card. If so, please let me know if the card can only receive ST2110 or is the computer taking it as a standard network card with duo 100G ports and you can also send all sorts of media over it.
JarkkoRx
#27 Posted : Monday, February 2, 2026 6:45:08 AM(UTC)
JarkkoRx
Finland
I'm testing with Decklink IP/SDI, which supports two channels in or out. It is shown just like any other Decklink card, as a video input/output device in OS, not as a NIC. I believe the same goes for the 100G model, which probably just shows as 8 in or out. Too bad it probably doesn't support more than 8 though...
mavik
#28 Posted : Friday, February 13, 2026 11:52:43 PM(UTC)
mavik
Thank you for the feedback
jet on 2/21/2026(UTC)
jonas.rau
#29 Posted : Saturday, February 21, 2026 12:26:44 AM(UTC)
jonas.rau
Germany
vMix is more and more used in professional broadcast and event environments, where the support of 10 bit and HDR will get necessarry in the next time.
It would be great if we could continue using vMix for those productions and not only for streaming, as it's such a powerfull tool!
thanks 1 user thanked jonas.rau for this useful post.
nzsp
#30 Posted : Monday, July 6, 2026 3:42:36 PM(UTC)
nzsp
New Zealand
+1
We use vMix in a professional broadcast faciltiy with 2110 (think tv station)
we've got 8 vMix we use for utility recording, handy multiviews, desktop capture via NDI to SDI etc
Using 2110 Decklink cards, we can only output 8bit streams, and other broadcast / tv grade products cant recieve the stream because they only work in 10 or 12 bit, not 8.
8bit support was manageable by OBS, surely vMix can figure it out!
thanks 1 user thanked nzsp for this useful post.
leo.goehrs
#31 Posted : Tuesday, July 7, 2026 5:51:48 AM(UTC)
leo.goehrs
+1
indeed, you can receive fine with BM 100G, and output to another vmix, but most 2110 like converter 3x3 and 2110 converter only support 10bits
we had to install a sdi card and send the outputs to a 2110 converter
not having 10bits render vmix incompatible with the 2110 eco system
leo
thanks 1 user thanked leo.goehrs for this useful post.
jet on 7/7/2026(UTC)
mnmilos
#32 Posted : Wednesday, August 5, 2026 11:29:35 PM(UTC)
mnmilos
Serbia
+1 Also need 4:2:2 for SRT output.
thanks 1 user thanked mnmilos for this useful post.
jet on 8/10/2026(UTC)
obviousc
#33 Posted : Monday, August 31, 2026 10:53:31 PM(UTC)
obviousc
Canada
+1
We need 10 bits to use vMix with some of the new Blackmagic 2110 products.
thanks 1 user thanked obviousc for this useful post.
jet on 8/31/2026(UTC)
ThommiTechnik
#34 Posted : Monday, September 14, 2026 12:00:37 AM(UTC)
ThommiTechnik
Switzerland
And: it's not only about HDR. Every broadcast-camera (Sony, GV, Ikegami, Blackmagic) is working on 10bit, even when working in HD SDR. So, unless vMix will not work with 10bits, it's useless for public-broadcasters, like us. It's a pity, what time I'm using at the moment, to bring all features we/I need to OBS, just because of 10bit. SloMo-controllers, Mixing-Panels, and so on.
thanks 1 user thanked ThommiTechnik for this useful post.
jet on 9/14/2026(UTC)
jet
#35 Posted : Monday, September 14, 2026 12:45:44 AM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Yes. The situation has been very frustrating for years.. and years..
Let's hope and demand vMix 30 will now finally bring it up to todays specs - in this area.
And many of us vMix users have had problems many years - and still have - with the reliability of SDI output (starting External-output), especially with BMD bi-directional I/O hardware like BMD DeckLink Duo 2, BMD DeckLink SDI Micro and BMD Decklink 8K Pro.
mavik
#36 Posted : Wednesday, September 16, 2026 12:16:35 AM(UTC)
mavik
There was unfortunately no mention of 10bit with the vMix 30 demo at IBC. But hopefully it will make it.
2 Pages<12
