Feature Requests
10 bit input and output support
Joined: 2/17/2021(UTC) Posts: 18  Location: Oslo Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
 1 user thanked JacobLarsson for this useful post.
Joined: 11/21/2023(UTC) Posts: 9  Location: Farroupilha/RS Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
 1 user thanked eddysangalli for this useful post.
Joined: 9/8/2023(UTC) Posts: 9  Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
 1 user thanked Justingonz for this useful post.
 1 user thanked mavik for this useful post.
Joined: 8/27/2025(UTC) Posts: 2  Location: Helsinki Was thanked: 1 time(s) in 1 post(s)
I have bumped into a problem that would be solved by 10 bit output.
In ST2110, I have noticed that many of the devices only support 10 bit, and fail with 8 bit.
I'm testing Decklink IP card with vMix, and this is the case currently with many ST2110 receivers. I'm working around this issue with CasparCG, which outputs 10 bit to Decklink and just takes vMix NDI output to the Decklink.
So basically, this case would be solved by just converting 8 bit to 10 bit in the name on compatibility, not in the name of picture quality :)
I know my idea is bad and will not support the efforts of the community trying to get real 10 bit output.
 1 user thanked JarkkoRx for this useful post.
Are you testing with the BMD 100G card. If so, please let me know if the card can only receive ST2110 or is the computer taking it as a standard network card with duo 100G ports and you can also send all sorts of media over it.
Originally Posted by: mavik  Are you testing with the BMD 100G card. If so, please let me know if the card can only receive ST2110 or is the computer taking it as a standard network card with duo 100G ports and you can also send all sorts of media over it. I'm testing with Decklink IP/SDI, which supports two channels in or out. It is shown just like any other Decklink card, as a video input/output device in OS, not as a NIC. I believe the same goes for the 100G model, which probably just shows as 8 in or out. Too bad it probably doesn't support more than 8 though...
Thank you for the feedback
Joined: 2/20/2026(UTC) Posts: 1  Location: Cologne Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
vMix is more and more used in professional broadcast and event environments, where the support of 10 bit and HDR will get necessarry in the next time. It would be great if we could continue using vMix for those productions and not only for streaming, as it's such a powerfull tool!
 2 users thanked jonas.rau for this useful post.
Joined: 7/6/2026(UTC) Posts: 1  Was thanked: 1 time(s) in 1 post(s)
+1
We use vMix in a professional broadcast faciltiy with 2110 (think tv station) we've got 8 vMix we use for utility recording, handy multiviews, desktop capture via NDI to SDI etc
Using 2110 Decklink cards, we can only output 8bit streams, and other broadcast / tv grade products cant recieve the stream because they only work in 10 or 12 bit, not 8.
8bit support was manageable by OBS, surely vMix can figure it out!
 1 user thanked nzsp for this useful post.
Joined: 6/12/2022(UTC) Posts: 1  Location: Paris Was thanked: 1 time(s) in 1 post(s)
+1 indeed, you can receive fine with BM 100G, and output to another vmix, but most 2110 like converter 3x3 and 2110 converter only support 10bits
we had to install a sdi card and send the outputs to a 2110 converter
not having 10bits render vmix incompatible with the 2110 eco system
leo
 1 user thanked leo.goehrs for this useful post.
Joined: 8/14/2023(UTC) Posts: 14  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
+1 Also need 4:2:2 for SRT output.
 1 user thanked mnmilos for this useful post.
Joined: 1/30/2021(UTC) Posts: 2  Was thanked: 2 time(s) in 2 post(s)
+1 We need 10 bits to use vMix with some of the new Blackmagic 2110 products.
 1 user thanked obviousc for this useful post.
Joined: 1/27/2019(UTC) Posts: 37   Location: Bern Thanks: 5 times Was thanked: 8 time(s) in 7 post(s)
And: it's not only about HDR. Every broadcast-camera (Sony, GV, Ikegami, Blackmagic) is working on 10bit, even when working in HD SDR. So, unless vMix will not work with 10bits, it's useless for public-broadcasters, like us. It's a pity, what time I'm using at the moment, to bring all features we/I need to OBS, just because of 10bit. SloMo-controllers, Mixing-Panels, and so on.
 2 users thanked ThommiTechnik for this useful post.
Joined: 11/14/2012(UTC) Posts: 398  Location: Finland Thanks: 252 times Was thanked: 39 time(s) in 37 post(s)
Originally Posted by: ThommiTechnik  And: it's not only about HDR. Every broadcast-camera (Sony, GV, Ikegami, Blackmagic) is working on 10bit, even when working in HD SDR. So, unless vMix will not work with 10bits, it's useless for public-broadcasters, like us. It's a pity, what time I'm using at the moment, to bring all features we/I need to OBS, just because of 10bit. SloMo-controllers, Mixing-Panels, and so on. Yes. The situation has been very frustrating for years.. and years.. Let's hope and demand vMix 30 will now finally bring it up to todays specs - in this area. And many of us vMix users have had problems many years - and still have - with the reliability of SDI output (starting External-output), especially with BMD bi-directional I/O hardware like BMD DeckLink Duo 2, BMD DeckLink SDI Micro and BMD Decklink 8K Pro.
There was unfortunately no mention of 10bit with the vMix 30 demo at IBC. But hopefully it will make it.
Originally Posted by: mavik  There was unfortunately no mention of 10bit with the vMix 30 demo at IBC. But hopefully it will make it. They announced 8 bit to 10 bit conversion... a sticking plaster solution. That's sad. Maybe we get the real 10+ bit version of vMix when vMix 30.5 is released :)
Feature Requests
