Joined: 8/30/2014(UTC) Posts: 2 Location: North Carolina
Hey, I’m using the title designer to create a custom title and I would like for the title to be positioned all the way at the bottom of the output screen when displayed. When I create the title in the title designer I have it positioned all the way at the bottom but when I add it as an input in vMix it is up a little bit. I have to go to the properties and set the Y pan to -0.26. Is there any way to set that as the default position so I don’t have to change the properties that every time I add that new title?
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
It sounds like you are not using Widescreen in vMix. If this is the case you will need to create a template in title designer that suits the chosen aspect ratio.
Click New then choose either 720x480 or 720x576 as the template size.
Martin vMix
Thanks Martin, I’m currently using the free version but fixing to upgrade to the HD version. After I’ve upgraded I’ll see if I still have that problem because I want to have a 16:9 output anyway. Rick
