rstambach
#1 Posted : Saturday, August 30, 2014 9:43:56 PM(UTC)
rstambach
Hey, I’m using the title designer to create a custom title and I would like for the title to be positioned all the way at the bottom of the output screen when displayed. When I create the title in the title designer I have it positioned all the way at the bottom but when I add it as an input in vMix it is up a little bit. I have to go to the properties and set the Y pan to -0.26. Is there any way to set that as the default position so I don’t have to change the properties that every time I add that new title?
#2 Posted : Sunday, August 31, 2014 6:41:15 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
It sounds like you are not using Widescreen in vMix.
If this is the case you will need to create a template in title designer that suits the chosen aspect ratio.
Click New then choose either 720x480 or 720x576 as the template size.
rstambach on 9/1/2014(UTC)
rstambach
#3 Posted : Monday, September 1, 2014 9:01:26 PM(UTC)
rstambach
Thanks Martin,
I’m currently using the free version but fixing to upgrade to the HD version. After I’ve upgraded I’ll see if I still have that problem because I want to have a 16:9 output anyway.
Rick
Similar Topics
Enable JPEG in GT Title Designer (Feature Requests)
by offroadmediagroup 11/3/2026 2:59:29 AM(UTC)
GT Title Designer - allow it to parse HTML Markup from a datasource (Feature Requests)
by Hypohamish 3/23/2026 11:19:46 PM(UTC)
"How can I do this through the Title Designer program?" (GT)
by bulent_atlas 6/26/2025 11:11:42 PM(UTC)
Allow for Alpha values on Layers in GT Title Designer (Feature Requests)
by offroadmediagroup 4/9/2025 8:42:08 AM(UTC)
Allow for nested layers within GT Title Designer (Feature Requests)
by offroadmediagroup 4/9/2025 8:36:47 AM(UTC)
Make GT Title Designer Locking Layers ACTUALLY Lock (Feature Requests)
by offroadmediagroup 4/9/2025 8:18:59 AM(UTC)
Allow Multi-Selected Layers Feature Changes in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 3:30:15 PM(UTC)
Update Default Behavior to Move via Arrows in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 2:21:05 PM(UTC)
Retain Order When Copy/Pasting Layers in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 2:10:15 PM(UTC)
GT Title Designer not importing PSDs with text in it (GT)
by Woogi 3/22/2025 8:22:39 AM(UTC)
GT Title Designer "Snap to" Safe Zone (Feature Requests)
by WaltG12 9/21/2024 5:59:44 AM(UTC)
vMix GT Title Designer (GT)
by Seetha Ramaiah Velicheti 7/20/2024 6:51:44 PM(UTC)
Adaptive Table for GT Title Designer (Feature Requests)
by scronk03 4/19/2024 3:12:55 AM(UTC)
GT title designer transitionin (GT)
by Pepsi(~) 4/19/2024 1:01:11 AM(UTC)
Feature in GT Title Designer and DataSource (Feature Requests)
by Ham4u62 3/27/2024 12:07:21 AM(UTC)
GT Title Designer NO FUNCIONA CON AMD (GT)
by angel guerrero 2/23/2024 10:16:46 AM(UTC)
GT Title Designer - image sequence (Feature Requests)
by AndrzejK 12/26/2023 8:54:40 AM(UTC)
GT Title Designer Request (Feature Requests)
by Simsyuk 2/24/2023 12:43:38 AM(UTC)
Can't launch GT Title Designer for some reason. (GT)
by ralston 2/2/2023 10:24:07 AM(UTC)
Add Keyboard Shortcuts for GT Title Designer (Feature Requests)
by jameslex 1/27/2023 12:43:41 AM(UTC)
Different Font settings within the same field in Title designer (Feature Requests)
by Paul Camino 9/12/2022 2:02:28 PM(UTC)
GT Title Designer - Auto sized right align text (Feature Requests)
by Huwenator 6/21/2022 3:10:31 PM(UTC)
Animatable layer position in GT Title Designer (Feature Requests)
by Mr. Broadcast 5/10/2022 9:24:41 PM(UTC)
关于 GT Title Designer 的几点建议 (Feature Requests)
by nthjz 3/31/2022 12:23:29 PM(UTC)
line height in GT Title Designer (Feature Requests)
by PDU_Mikhail 3/3/2022 4:23:05 AM(UTC)
☝️ Leading Option in vMix GT Title Designer (Feature Requests)
by Pointer 2/1/2022 4:24:37 AM(UTC)
GT Title Designer Bounding Limits (Feature Requests)
by Ryan_AlleganyMedia 10/27/2021 11:25:09 AM(UTC)
Auto squeeze text - GT title designer (Feature Requests)
by Hylkewolf 1/11/2021 8:15:43 PM(UTC)
Standalone GT Title Designer (3rd Party Software and Development)
by rhodian 10/26/2020 6:03:23 PM(UTC)
Colour Picker in GT Title Designer (Feature Requests)
by colintve 10/14/2020 8:35:26 AM(UTC)
